Thread: Exide 31-950 anyone used one
    Ellendale Tasmania.
    I got a good deal on an Exide 31-950 Calcium/Lead Calcium battery from Exide in Padstow, $155 pick up, has anyone had any experience with this battery, considering the equivalent Century 86ZMF is $278.
    These are the closest spec to the OEM Delphi Freedom that comes in the TD5.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Padstow NSW
    its exide you wont have any problems! century on the other hand
    and 155 is cheap
    cheers phil
    Good work Baz.
    Can you do a follow up on your voltages to see if it makes any difference?
    I also tried to find the specifications of the battery to see if there is a sight glass which shows the charge state. If there is can you keep a lookout for any changes.
    Cheers.
    Padstow NSW
    if its calcium/lead calcium it will probably sealed and wont be a true wet battery, so the sight glass wont exist
    cheers phil
    Ellendale Tasmania.
    Quote Originally Posted by feral View Post
    Good work Baz.
    Cheers.
    No sight glass, the battery I'm replacing has one, (Century 86ZMF) It's called Magic eye, buggered if I could tell the charge level by it
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
