Results 1 to 9 of 9
Thread: d1 steering stoppers
    Jul 2008
    im hoping someone can give me a rundown on steering stoppers on a d1, ive put 265/75 on and they hit the radius arms on full lock
    Wonthaggi, Vic
    G'day Jeep Boy
    Someone on here may chip in with a bit more of a technical response but I'll give you the laymans version.
    Look under your Disco at the CV joints from the front. You will notice a bolt sticking out just in front of the CV joint, it will probably be sticking out about 5 cm or so, you will notice it because it looks a little weird. That is basically your steering stop, adjust those out a bit and you should find it will solve your rubbing business ..... hope this helps .....
    Someone correct me if i am wrong ....Cheers
    Jason
    I'm pretty certain it is the same as on my 110 on your D1 - if not, someone will correct me!
    On the front of each swivel housing you will find a large bolt whose head hits the flange on the sphere when on full lock to the opposite side. This is your adjustment. It has a lock nut on the other side of the housing. Book says 20mm clearance between the tyre and the radius arm.
    Hope this helps.
    Jul 2008
    thanks guys i thought they were the ones ill give em an unwind, will they need loctite
    Quote Originally Posted by jeep_boy View Post
    No, loosen the nut on the back, adjust it then tighten the nut. Loktite won't hurt, but is unnecessary.
    Ferntree Gully, Vic
    G'day jeep boy.Ive just bought some 265/75 for my Disco as well second hand.Mine are going on the 16 inch alloy.Do you have a lift on yours and do they rub the guards much? Also do they stick out past the guard at all? I was about to start a thread about it but you might be able to tell me.Thanks
    Chris
    Jul 2008
    Quote Originally Posted by SPROVER View Post
    Chris
    na mate no lift, they did rub on the radius arms but that was easy and i had to chop the guards a little, have a look in projects and tutorials i have a few pics in there
    Dec 2008
    Geelong, Victoria
    We talked about it here, I put a few pics on which may help:
    http://www.aulro.com/afvb/discovery/...tire-size.html
    Scott.
    Ferntree Gully, Vic
    Cheers.Thanks for that Scott.
