There are actually a few items you may need to consider. The EFI vehicles had a submerged fuel pump with a full flow fuel return, where most if not all the carby V8's had external fuel pumps (or at least that was my RRc - carb->EFI conversion). The fuel flow is controlled by the throttle position sensor so you need the right fuel pump and return line. I ended up getting a long range tank with the submerged pump during the conversion which solved the pump and return line issues.
As long as you get the complete engine harness all the way back to the ECU along with the other bits like the MAS your biggest problem is going to be mounting the extra bits.
