Results 1 to 10 of 17
Thread: '54 S1 86" Gearbox Mounts
    Bunbury, WA
    Question '54 S1 86" Gearbox Mounts
    Does anyone know where I can source gearbox mounting rubbers for a '54 S1? I am after a set (2) of the two piece ones. FWD in Vic said they cannot get any for love nor money
    If they are not available, what does one do (get a block of rubber and start whittling??)
    Oct 2007
    Red Cliffs
    Mounts
    Each year at the Bendigo swap meet there is a retailer selling rubber bits, light mounts, engine mounts etc. For the last 3 years he has had sets of mounts off some thing that are the same as the lower large cone bit with bolt, washers and nut the top bit is a little different but looks like it would do. I have only one set left and meant to buy some last year.
    Can’t remember the name of the retailer will try to find out.
    Dennis
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Quote Originally Posted by dennisS1 View Post
    Dennis
    Classic Obsession?
    Oct 2007
    Usually in Griffith NSW
    I saw a range of mounts that looked like it might include a suitable one for the gearbox in a catalogue for Dunlop Industrial Sales, many years ago now. But you might try an engineering supply firm with a good range, they could be available for general machine mounting
    Nov 2006
    Wollongong NSW
    Rubber mounts
    Try Mackay Industries. They make a large range of rubber mounts for a lot of applications. They used to have something close .
    **edit**
    Heres the catalog from there website. Look at page 58
    http://mackayrubber.com.au/pdf/industweb.pdf
    Are these the type of rubber mounts that you are looking for?
    Aaron.
    Nov 2007
    Cedar Grove SE QLD
    Hey Aron where did you get them from? and do they have any more???
    Gear box mounts
    Hi
    do not cut your wrist's
    any mount that has a similar cross section will do the job
    there are 100's of profiles out there that will do the same job
    just make sure it is similar in hardness
    Ian
    I may have a spare let lying around.
    Aaron.
    For those that are still interested, I will soon be fitting a set of my pictured mounts to my 80". I will let you know how well they fit. I will have some spare that will be available.
    Aaron.
