Results 1 to 10 of 16
Thread: Quick Swivel Ball Question.
    Kiwiland
    Are swivel balls handed or interchangable left to right?
    I've never had both off at the same time.
    Talking coil spring axles (RRC, D1 etc).
    Christchurch NZ
    Interchangeable, they are not handed
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Warburton, Victoria
    Stand to be corrected but they are LH and RH.....
    Yes, I was pretty sure they were left and right as well. I just need to think about it for a bit.
    Yinnar South, Vic
    Quote Originally Posted by sclarke View Post
    Well quite standing
    They only become "sided" if you've had them slotted for castor correction
    Yes, I have thought about it and they are not sided if you buy them new.
    However, if using 2nd hand swivel then there is likely to be a slight groove/depression where the oil seal runs so you would only want to use a 2nd hand one on the same side that it came off.
    My swivels were slotted which got me confused because then they are LH or RH
    Christchurch NZ
    Only one part number..........................
    FRC7065 Swivel housing - front axle from LA930456
    Safety Bay
    I would refit the same side they came off or get second hand ones from that same side. Pat
    ambidextrous, just dont cross order the series for the county+ ones.
    Yinnar South, Vic
    Quote Originally Posted by PAT303 View Post
    Why?
