Personally - I'd go for a MillWeld (winch bars-rock sliders-4x4 snorkels-custom bar work) competition bar (about $990) which is cheaper - stronger - lighter - and nicer looking than the ARB. See MILLWELD
Or alternatively Scopion Racing do some nice bars - and Rovercraft import them (Also around the same price.) Last time I priced an ARB bar it was much more expensive than that.
There are apparently some good deals on less well known brand winches - and various review articles floating around. One advantage of a brand name winch is that the parts are easy to get - but it will be expensive. If price is a consideration - then I'd look at some of the less expensive winches on eBay. I've seen a few there that cost around $600 that seem to be reviewed quite well.
One slight issue I've seen on the SVX is that the black interior shows dust up really easily, and once it's dusty it's hard to make it look nice again. If that would bother you, then before you go out anywhere in it, get 2-3 tubes of Sikaflex and seal up all of the gaps in the body work. (Or hassle the dealer until they do it.) The New defender has no underseal which make it suck dust in like crazy through the little gaps in the panels. Ive got a little volcano happening in the rear of mine!.
FYI - The tyre size on the defender is 235/85/r16 which I think is not a size normally fitted to a Disco? The Stock Defender tyres are General Grabbers and are actually quite good as an All Terrain type tyre.
 ) to the SVX, but still want
