Results 1 to 9 of 9
Thread: How is it done?
    How is it done?
    A clue from Jeremy Bowdler (Editor Two Wheels)
    Quote Originally Posted by Jeremy
    Ho hum. That old thing? Suggest a quick search for Franco Sbarro. You might turn up a thing or two…
    If you're feeling adventurous, you could always ask for a test ride on the McLean Wheel...
    See Jalopnik:
    http://njection.com/blogs/jalopnik/a...torcycles.aspx
    Aug 2008
    That is one wild looking bike!
    NSW , Pennant Hills
    ....Hubless wheels work by fixing the rotating parts (brake ring, bearings, hubless rim) onto the outer side of a non-rotating inner ring that attaches to the motorcycle’s swingarm or forks....
    Shepparton
    I understand how the front end works but how in the hell is the rear driven?
    One radical looking bike, I also like the comment of " it was not designed to be riden"
    mike 90 RR Guest
    Quote Originally Posted by crash View Post
    Think of it as a 2 piece rim .... The silver shiny drum part that you see (does not turn) & is fixed to a X brace that is covered with those Triangle red covers .... All you need is a drive shaft and then a 90 degree diff to return it to a massive "gear ring", that is in between the fixed (silver shiny) drum & connected to the wheel rim
    Mike
    Barossa Valley
    wheres the brakes?
    mike 90 RR Guest
    Quote Originally Posted by mightgeta4be View Post
    wheres the brakes?
    Think ..... "Flinstones"
    NSW, Australia
    The brakes are made of leather and are worn by the rider.
    [B][I]Andrew[/I][/B]
    [COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
    [COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
    [COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
    [U]1995 Defender 110[/U]
    [SIGPIC][/SIGPIC]
