heres mine,
keeping the bottom of winch with the bottom of the chassis rail is better practice, but it will reduce the approach angle.
My initial thoughts also, to have the bottom of the drum in line with the middle of the chassis rails (as in front pic) to avoid a bending moment applied to both the bar and the mounting bolts. The chassis rails look sturdy enough not to worry.
If I were to raise the mount height, I'd have to stiffen the winch mount tray with a plate either side, going all the way back to the chasis mount.  I figure can lift it by ~5cm before introducing any real bending moment, but would ideally want to go up to 10 cm. Hmmm... thoughts?
if you dont have A/C, and you have a TDI or td5  i would definately consider a full width intercooler and rad...
Cheers  , this one's a V8 - my oiler is getting a full width intercooler tho, just needed to figure out where to fit it.
my winch is quite close to my A/C condensor, about 25mm, you may get some flexing, but you want that craddle to be pretty damn stout, and fixed to the chassis well to do its job anyway.
I was more worried about untidy cable damaging the radiator - do you have any sort of a shield around the winch drum to stop the cable from touching the rad?
if my winch touches my A/C condensor or rad, i've had a pretty major impact, that having no winch wouldnt really matter anyway.
X 2
Serg
