Thread: front output shaft
    malsgoing130 Guest
    front output shaft
    Hi all,
    I did something stupid this morning, i was checking the Prop shaft bolts and nuts and shook the front prop shaft at the transfer case and saw alot of movement- !@#@$%$ .The question is can the bearing be replaced without removing the whole transfer case and what are the chances of the housing being worn.????
    cheers Mal
    Christchurch NZ
    Quote Originally Posted by malsgoing130 View Post
    Hi all,
    cheers Mal
    Yes they do move, even in good condition. When they start to leak from excess movement or vibrate it's time for bearing replacement. To replace them, drain the oil, remove the front shaft, then the flange (one big nut), remove the seal, then the circlip that holds in the bearing. Replace the flange and pull the bearing and shaft out with a slide hammer attached to the flange. Remove the bearing from the shaft. To refit, reverse the process.
    1995 Defender 110 300TDI :D
    1954 86" Series 1 Automatic :eek:
    Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
    Bazil Guest
    Front output bearing
    Thanks Jimbo, saved me a great deal of trouble
    Cheers.
    Jan 2011
    new england
    Quote Originally Posted by jimbo110 View Post
    How far out can the shaft come and still be easy to push back in?
    Christchurch NZ
    Take it all the way out, you just need to line the splines up again when you are driving in the new bearing.
