lately i have been doing a lot of 4wding and i have a good whine coming from the front end,, i'm pretty sure I've put it down to the diff, all the props are lubed well and there is new oil in the diffs and no water in them ,,
the most i can say about it is its at its worse when cruising and just a tiny bit of throttle to keep the same speed up, and it happens on run down,, and when accelerating, but it goes away when i'm say going up a hill and full throttle(td5 defender so you have to have full throttle
) under full load,
all I've found is that i can turn the front prop about a 1/4 of a turn before it takes up, and i feel this is too much, am i right?
there is a lot of drive line slack it feels when driving, and if your a bit too hard it will clunk like hell,
any way can i tell if its the diff with out removing it? but i think i will anyway to check it out, but just to make sure??
1995 Defender 110 300TDI :D
1954 86" Series 1 Automatic :eek:
Ex '66 109" flat deck, '82 109" 3 door, '89 110 CSW V8, '74 Range Rover, '66 88" soft top, '78 88" soft top, '95 Disco ES V8, '88 Surf, '90 Surf, '84 V8 Surf, '91 Vitara.
