Results 1 to 10 of 18
Thread: D3 Steering wheel Audio controls (retrofit)
    Mornington Peninsula and Hong Kong
    G'day Guys -
    I have a quote on the part from LR which is $140. sounds god so far... Fitting cost was quoted at $450?!?...
    Anyway, I am of average to above average mechanical/technical ability and think I will buy this and do myself.
    Does anyone have the tutorial for the retrofit? or can give me some ideas on how to remove and install the new one? As I know removing the steering wheel, disconnecting the battery and replacing the blank with the new controls is the high level concept.
    HOwever, I am sure I read a step by step somewhere on this....might have even had pics?
    Let em knwo if you have done this or have reference to the changeover process...
    Thanks a million!
    Quinnyii Guest
    Def90,
    Have a quick search on the UK disco3 site,there is a good tutorial there, I know that it is a fairly simple procedure although i have not done it myself, i believe once the panel comes off the wheel it is already prewired and simply plug and play.
    Pat
    Having followed the Disco3 tutorial, it is quite simple and only takes about 5 minutes. It takes longer to make the "tool".
    Up a hill in the deer park
    Thanks for all the help on this....
    I wont be getting the dealer to do it, but will do it myself and also take some pics of the process.... at the same time I will do the ipod lead from the passenger side footwell. It will be some of my planned easter activities...
    will keep you posted on how it goes..
    May 2008
    got a quote from the dealer, $372, includes fitting cost, might go for it one of these days as fiddling with the master button on the left hand side can get tricky sometimes, specially when a 4 a yr old keeps saying "i can't hear dad"
    That's an utter rip off !
    May 2008
    I believe they're also known as "stealers" . Kidding aside, the quote I got was $238 for the unit and the fitting cost is $154. So if it's really easy to install with the step by step instruction, I might just do it myself.
    Def90, which LR dealer did you get a quote of $140 for the unit?
    thanks
    Jan 2009
    I ordered mine from UK through Nick Lee (partsmanager@landrover-yeovil.co.uk) at Yeovil LR. 30 Pounds including postage.
    Arrived this morning and took about 10 mins to install.
    Andrew
    PS. The instructions are not very clear on using the tool. When using the tool to remove the airbag the hook faces you, if you are sitting in the drivers seat. Apply pressure towards you and pull back on the tool to release the airbag.
    May 2008
    [QUOTE=amaruskanic;956328]I ordered mine from UK through Nick Lee (partsmanager@landrover-yeovil.co.uk) at Yeovil LR. 30 Pounds including postage.
    Can I just ask, is it just the audio controls (volume) or radio control too?
