Results 1 to 10 of 38
Thread: 130 steel rims VS wolf rims
    Nov 2007
    Gold coast
    Iam confused
    Ok. Are wolf Rims, the same Rims that you would find on a 130? they look very much the same????
    East-South-East Girt-By-Sea
    1.20 MB
    To put it another way.
    Some 130's have wolf rims.
    Nov 2007
    Gold coast
    Indeed. so the question is, what are the rims that come standard with a 130 called? And are they different to wolf rims?????
    Adelaide Hills - SA
    The Wolf rims are not the same as the 130 standard rims.
    The steel is heavier (each Wolf wheel weighs noticeably more than a standard rim), and you can get Wolfs in Tubeless whereas the 130 rims are for Tubed tyres only.
    Look for the part number ANR4583 if you want the tubeless Wolfs.
    1.20 MB
    Quote Originally Posted by juddy View Post
    Standard 130 rims look very much the same as every other standard Defender, County, 110 or series rim although they have a 6.5" width.
    This is a standard 130 rim.
    Nov 2007
    Gold coast
    Thats not the type of rim you get standard on a new 130?
    Nov 2007
    Gold coast
    These are standard rims. are they tube or tubeless?
    1.20 MB
    You never said NEW
    That one is a 130 rim but not the current model.
    Nov 2007
    Gold coast
    ok you are right i never said new, let me start again.
    New as in brand new 130 what rims come with it?
    TD5 130 what rims came with it
    TD3 130 what rims came with it
    Toowoomba QLD
    130 rims with holes are essentially Wolf rims.
    They can be either tubeless or tubed type (slightly different rim profile) depending on age. All have a thicker center section than 110 rims and more offset and are 1/2" wider (6"). They are also heavier, despite the holes.
    Some will argue that they have to be the tubeless type to be called Wolf rims and while this may be strictly correct, its probably getting a bit picky......
