Results 1 to 10 of 28
Thread: L322 Brake service costs
    Well got the L322 back from the dealer, with new rangies don't just change the pads evey 35-50ks they insist on changing the rotors as well at $1200 because the weight of the vehicle it eats into the discs. So the cost,which I thought is not too bad, service and brakes $2400 for all you budding L322 owners.
    Apr 2007
    Prospect SA
    Not too bad!!!
    Modern discs are meant to wear, I get that but it seems the running costs of these vehicles just keep on getting higher.
    Beutiful cars, no doubt but there must be aftermarket people doing discs and pads at much more competitive prices!
    Adelaide Hills - SA
    Hi Dawg - Thanks for bringing some joy to my morning
    Haven't replaced the pads in mine, but I'll know what to expect when they tell me the pads are getting thin.....
    Quote Originally Posted by spudboy View Post
    My pleasure Boet, the only good news was the rubber boot on the key was U/S so they changed that under warranty....
    Sep 2010
    KHOR in BNE did my rear brakes and machined the rotors for about $400.. Ive done about 15k since without so much as a squeek!
    Rim
    __________
    '06 Range Rover Vogue TD6
    Aug 2010
    Sunbury, VIC
    Front disks can be had new for about $50 each + postage from places like Britishparts. Rears are around $35 each + postage. Pads are $40 for the front and $35 for the rears. So for under $250 + delivery, these are one cheap machine to do the brakes on - cheaper than my old Commodore or my Daugthers 92 Pulsar! I wouldn't ever worry about machining or anything, when the pads are worn, replace the whole lot, and they are easy to fit. The whole front and rear suspension/brakes/etc are all very easy to work on for the average DIY'er with a basic tool kit.
    This is one upside to owning a car like this - there are heaps of places selling aftermarket parts, and a lot of them are quite cheap when you think about the cars original value, and what the stealers are asking for parts...
    tebone Guest
    Quote Originally Posted by bacicat2000 View Post
    I agree with you bacicat2000,
    I replaced my rear rotors and pads for $250. Easy to replace yourself and have done about 20K's since with no troubles. Alot of people out there are quick to rip you off when you mention range rover.
    regards Paul
    Sep 2010
    Thanks a heap lads. I appreciate the heads up. Front brakes will prob need replacing shortly, so I will definitely have a go myself and invest the $$ into converting my tv to digital!!
    Rim
    __________
    Apr 2007
    South Australia
    Mine needs new fronts at least as I cooked them a bit in the hills yesterday and they are slightly warped and going by the service records the fronts are 65k old. Any aus suppliers or internet/UK?
    2007/2002/2000/1994/1993/1988/1987/1985/1984/1981/1979/1973 Range Rover 1986 Wadham Stringer
    and a Nissan Cube............
    South Australia.
    Jul 2008
    Cheltenham, Vic
    Our 03 has had a habit of warping its front rotors on a fairly regular basis, ended up just getting them skimmed about every 10,000km or so when it starts shuddering noticeably.
    Not had the same issue on our 08 S/C as yet, suspecting it may be somewhat more troublesome when it needs done what with the Brembos on the front.
    Anyone had to do the replacement on an S/C as yet by any chance? Know if the rotors/pads are specific or just the calipers that are different?
    Al
