Results 1 to 10 of 14
Thread: New Defender Hinges
    Jock The Rock Guest
    New Defender Hinges
    Well finally got around to fitting my new hinges and stainless bolt kit today
    Here's a few photos for anyone who's interested
    A few suggestions:
    • remove the inner door lining
    • definitely get a replacement bolt kit
    • take the door off first, then the mirror and then the hinge
    • buy Bearmach hinges if possible they are by far the best quality
    • when changing the top hinges on the front doors, be sure to swap over the little nylon spacer that prevents the mirror screws from ratteling loose. I found this out afterwards and had to pull one of the hinges off again
    Before:
    New Hinges:
    Half Done:
    Rear Door:
    Bonnet Hinges:
    Passenger Side:
    Drivers Side:
    Are the hinges painted? My replacement hinges came unpainted.
    Simon
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Look good Jock!!
    If you don't mind how much did they set you back?
    CHEERS TIM.
    Jock The Rock Guest
    Quote Originally Posted by abaddonxi View Post
    Simon
    Na I didnt paint them, just gave them a coating of grease all over. I reckon they will be right. If they start to rust then I'll know I haven't oiled them well enough
    I had a few hassles getting the hinges but the reason I suggest Bearmach is beacause it was the only hinge I came across with a protective coating. It was a plasticy wax like coating that looked really good. Unfortunately the supplier didnt have a set of them so I had to get Britpart instead
    Quote Originally Posted by long stroke View Post
    Look good Jock!!
    CHEERS TIM.
    Thanks mate
    $22.50 each then the bolt kit was about $70 from memory
    Stig's Stainless Fasteners
    And then postage on top of that
    Devonport, Tasmania
    Hi Jock
    Lookin good young fella!
    I like the ladder, you will have to be carefull though some of Lonny's traffic nazis may give you an infringement for having an obscurred number plate.
    Have you posted pics of the roof rack? I would like to see how it all looks. I am suposed to be heading up your way sometime in April, I will give you a call and see if we can have a quick catch up.
    Cheers Andy
    Jock The Rock Guest
    Quote Originally Posted by Andy-M View Post
    Hi Jock
    Cheers Andy
    Didn't think of that, the fella who made it specially made the rungs so they wouldnt obscure the lights, but forgot about the number plate. Might have to move that.
    Is there any particular place I can't have it?
    Theres some photos here of the rack but Ive had it powdercoated since and havent had a chance to post up some more photos.
    Roof Rack - How to finish?
    Yeh that would be good to catch up Hows Mongrel coming along?
    Jock The Rock Guest
    Well ...
    Lesson learnt. Put a protective coating on your hinges. I thought mine would be right with grease, that worked for a while. Then I gave them a good going over with oil, again that worked for a while. But they still got surface rust
    So today I pulled them off and gave them a coating with that fish oil and lanolin stuff. Hopefully it works
    Quote Originally Posted by Jock The Rock View Post
    cant you just move it to the other side? theres no number plate on that side
    Jock The Rock Guest
    I'll have a fiddle and see if I can move the Land Rover symbol. Otherwise it won't fit and I have to move the light as well but I guess that would have to be moved anyway
    Thanks for the idea DB. I was thinking also I might try and get one of those slim plates so I don't have to have the sticky outy bit on the outside
    Melb. Vic.
    Hinges look good Jock - I'm looking to do that job on Scruby soon.
    Maybe put the ladder on the other side - Then again, I s'pose it would foul the door
    Perhaps take the sticky-outy thing (love these technical terms!) off the port side, turn it upside down and rivet it to the starboard?
    Perhaps just wait and see if Mr Plod notices - I can still read your plate
