Results 1 to 6 of 6
Thread: Aircon/Blower/heating
    Rayngie Guest
    Hullo,
    does anyone know how the aircon / blower / heating system orks in a classic ( 1988 ) rangie?, aircon works fine, however, cant get any air onto the windscreen at all, and if i use it on the 'outside' air setting with aircon off, i get no air at all anywhere, face,feet windscreen.
    i do get hot air with the heater, so that works.
    Any idea's where i should start looking to make sure all pipes etc are heading where they should?
    ta,
    Ray
    Rosevale, Qld (south of the 'Switch)
    Mate, I have a similar issue which I posted a request for too - got no responses.
    I'll follow this with interest. If you work it out, would you mind letting me know too?!!
    Stu
    1993 Range Rover Vogue SE 3.9lt - languishing
    2 x 1981 3.5lt V8 2dr Range Rover
    1958 Series 1 109" - "Bob" - COVID project
    Who wants another politician as Head of State? Not me:
    http://www.monarchist.org.au/
    Douglas Park, NSW
    You need to read the owners manual for your RR.
    IIRC, the only A/C vents are the face level vents.
    To demist, put the switches/levers into the 'red' positions.
    Rangier Rover Guest
    Your vents are not switching? Have you got the left slide in downwards or set on max demist? The right slide does bugger all unless left one is down in both of mine. Are they vacuum operated? Is a linkage off a bell crank? Ph11 and earlier were cable operated and not prone to this trouble other than bell cranks snapping and felt seals leaking.
    If no vacuum check in the engine bay first. You can find leaks by getting a smoker to take a puff and blow it down the tube. The smoke will come out through the offending leak
    I had mine out not long ago so will try to find some pics of what it looks like.
    Tony
    Rayngie Guest
    Hi Scott,
    If I put the levers into the red, it does didly squat..it's only when io have the AC on that anything happens at all.
    Ray,
    Adelaide - Torrens Park
    Mine mostly does diddly squat too, and I am pretty sure it is all working correctly.
    Clearly the Poms had no idea about HVAC when they "designed" the system in the RRC.
