Results 1 to 10 of 13
Thread: Simple camp kitchen on the back door
    Dec 2008
    I thought that this modification made to my Defender 90 might be of interest to some folks. Basically it’s a drop-down flap that serves as a simple camp kitchen. It folds away to almost nothing and sets up for use in a few seconds. The pics illustrate.
    This shows it in its stored position, held in place with a turn-buckle.
    Dropped down with one side held in place with a turn-buckle.
    Both sides securely locked in place. It’s now quite rigid. Note the hinges. Piano hinges were used for the two side flaps, pop-riveted in place. The two stainless steel hinges have spacers behind them to provide the offset necessary to allow the flaps to be held in place behind the work surface when in the storage position. The natural springiness of the metal prevents rattles.
    Ready for a brew! It will take two of these single burner stoves if they are turned 90 degrees, or one two-burner stove, or a washing up bowl, or whatever. The work surface is 600mm x 300mm. The whole thing is made from 1.5mm aluminium. Capral Aluminium cut the pieces to size which saved me a lot of work. Shape cutting was done with a jigsaw, finishing with a file. Tip. Aluminium clogs files very quickly. Clean by rubbing a piece of copper pipe across the file blade.
    It weighs just a little more than the plastic-padded panel that was taken off.
    Detail of the turn buckle. I used three of these – one for each of the side flaps and one to hold the whole thing in the storage position.
    Next job is to fashion a device to lock the rear door in the open position.
    TBA
    Quote Originally Posted by Vin Rouge View Post
    [IMG]file:///C:/Users/Mike/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/IMG]
    [IMG]file:///C:/Users/Mike/AppData/Local/Temp/msohtmlclip1/01/clip_image004.jpg[/IMG]
    [IMG]file:///C:/Users/Mike/AppData/Local/Temp/msohtmlclip1/01/clip_image006.jpg[/IMG]
    [IMG]file:///C:/Users/Mike/AppData/Local/Temp/msohtmlclip1/01/clip_image008.jpg[/IMG]
    Ready for a brew! It will take two of these single burner stoves if they are turned 90 degrees, or one two-burner stove, or a washing up bowl, or whatever. The work surface is 600mm x 300mm. The whole thing is made from 1.5mm aluminium. Capral Aluminium cut the pieces to size which saved a lot of work. Shape cutting was done with a jigsaw, finishing with a file. Tip. Aluminium clogs files very quickly. Clean by rubbing a piece of copper pipe across the file blade.
    [IMG]file:///C:/Users/Mike/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg[/IMG]
    Hey mate I'd be pretty interested to check out your setup
    But when uploading photos you first have to upload them to the internet then attach them to your post
    Heres how you do it:
    Links and Downloads Manager - Australian Land Rover Owners
    Dec 2008
    Thanks Jock - if all else fails, read the instructions eh!
    Actually achieved it using Imageshack, but I'll know for next time.
    Feb 2009
    that's a ipper, thanks for sharing.
    Near Seven Hills, Sydney
    Before filing aluminium or lead based materials, rub a stick of chalk on the file, it will help stop the clogging.
    Mark
    Oct 2008
    That looks the goods!
    As for a way of holding the door open, I'll get some photos of my set up over the weekend. The guy I bought my car off has rigged up a small gas strut/hydruallic ram thing to push the door open. It works really well.
    Hervey Bay, Qld
    mate nice jobbie ...and im proud and if not bold to say, nice job on the draws as well.........
    Sandstone Point Qld
    Great Job .........
    Aaron & Jacinta
    1994 300Tdi Defender
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    Quote Originally Posted by cheyne_r View Post
    yeppa Ford Falcon bonnet strut is bang on
    TBA
    I thought that this modification made to my Defender 90 might be of interest to some folks. Basically it’s a drop-down flap that serves as a simple camp kitchen. It folds away to almost nothing and sets up for use in a few seconds. Next job is to fashion a device to lock the rear door in the open position.
    Looks great mate
    Might have to look into this one Thanks for the idea
    Pics would be great mate, I do have one of these struts somewhere off an old Falcon. And measurements would be great as well, even just rough ones
