Results 1 to 9 of 9
Thread: Dual Spare Wheel Carrier for 110
    pbroz Guest
    Does anyone know of who manfacturers the Dual Spare Wheel Carrier for the Defender 110? I've seen one around Fremantle and seems like a good way to carrier that 6th wheel (if required)...
    Jul 2007
    ARB I belive make one for the landcruiser
    if you do some searching on the forum you should find the drawings for a defender dual spare carrier. You could take that to your local engineering fabricator and they should be able tp knock one up for you.
    N Qld,
    Kaymar
    Apr 2007
    UK
    Quote Originally Posted by hook View Post
    Kaymar
    Unfortunately, they only make a single wheel carrier for the 110 / Defender, see at the bottom of this page:
    KAYMAR Defender
    Jon
    Tassie/Perth
    Kingston, Tassie, OZ.
    All the swing away parts can be bought, the Defender has the huge advantage of having the rear crossmember RIGHT THERE in your face
    Easy to make your own, and it'll be WAYYYY cheaper.
    JC
    Jul 2007
    I see cewilson found the drawings I was refering to earlier.
    rijidij has also put up some pics of a project he put together for a single wheel carrier. He found a good source for the bearing/hub to get the pivot. With a bit of imagination and a tape measure I am sure that you could come up with a dual wheel carrier.
    But as others have said, Why? For the times you need a sixth wheel you could find a storgae location for the trip. I used roof bars and put the spare up there.
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    Quote Originally Posted by slug_burner View Post
    I did 2 this trip, i know of 1 RR that did 3, and 3 otheres who were doing the 550klm trip home with nothing with air but the one in each cnr.
    and its horible driving with no swaybar and 4 wheels on the roof. even 2 is not so nice.
    Adelaide, SA
    I can't quite remember who to credit for this (needless to say it wasn't me), but here is a CAD drawing of a dual spare wheel carrier that I found on the forum some time ago.
    If you do decide to use it, I'd check all the mesurements just to be sure it fits.
    enjoy
    Bojan
    Attached Files Attached Files
