Results 1 to 10 of 15
Thread: How do I change a Serpentine belt?
    Hi All
    I am wanting to replace the serpentine belt on my 130 300 TDi.
    Is it just a matter of loosening the nut that holds the tensioner? I did this but the tensioner did not want to move. I didn't force it as I was not sure if this was the correct procedure.
    Andrew
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Which one (if yours has two). The fan belt only needs a 15mm ring spanner onto the centre bolt of the automatic tensioner pulley and then you lever it away from the belt. If I recall correctly, that's levering it as if you were trying to tighten the nut.
    Don't unbolt the tensioner at all.
    Free Again Thanks Dan
    On the 300 tdi there is no need to loosen any bolts just use a 1/4"(i think) or 3/8 breaker bar inside the tensioner and lever the tensioner away from the belt
    Dec 2008
    This is taken from the LR workshop manual. My notes are in italics. Note that the tensioner pulley is on an arm. It's this arm that you have to move to remove the tension on the belt. You don't need to touch the pulley bolt.
    Remove belt
    1.Remove fan cowl. LR recommend this but it’s usually just possible to fiddle the belt past it.
    2.Apply a ring spanner to the tensioner pulley retaining bolt. There’s a lot of tension on this, so take care if you want to retain the skin on your knuckles. You do need a decent spanner of the right size. Don’t use an adjustable spanner. If you have difficulty moving the tensioner, extend the spanner length by sliding a bit of metal tubing over it.
    3.Turn spanner to release pulley tension from belt.
    4.Detach the belt from pulley.
    5.Release the tensioner. Slowly!
    6.Complete removal of belt. Mark direction on belt if refitting.
    Refit
    1.Using ring spanner, release pulley tensioner and fit new drive belt.
    2.Remove ring spanner, drive belt will automatically tension.
    3.Fit fan cowl
    Quote Originally Posted by Vin Rouge View Post
    Remove belt
    Refit
    3.Fit fan cowl
    Yes a ring spanner now i remember
    Ok. thanks for the help.
    I did loosen the 15mm nuts that holds the tensioner arm to the front of the motor. The nut was quite easy to undo. The tensioner arm did not move when I undid the nut.
    Do I move the tensioner arm downwards to relieve the tension?
    I think I was trying to move it upwards.
    Andrew
    Andrew
    Feb 2005
    Quote Originally Posted by 86mud View Post
    Andrew
    clockwise from memory
    Tighten them back up then leave 'em alone
    Move it away from the belt. I don't have a 300Tdi to check the direction but probably clockwise.
    Aug 2008
    As mentioned, re-tighten the bolt that holds the tensioner onto the engine.
    Make sure you note the path of the belt before you remove it.
    Then put a 15mm ring spanner onto the nut that holds the actual pulley onto the tensioner arm (the one in the middle of the round pulley).
    You will probably need a breaker bar or some type of tube over the spanner to give enough leverage to move the tensioner, it holds alot of tension.
    Then move the spanner (or breaker bar, tube) ANTI-clockwise to lift the tensioner up and away from the belt.
    While holding the tensioner away from the belt, slip the belt off and slowly release the tensioner.
    Belt off.
    Now I understand.
    Thanks to all that replied.
    Andrew
    Andrew
