Results 1 to 10 of 16
Thread: 3.5 litre cylinder
    May 2008
    Romsey, Victoria,
    3.5 litre cylinder
    Any one agree or disagree that if the 3.5 litre motor is overheated that they are liable to loosen a cylinder liner?
    Mine is currently rattling like loose tappets but the rattle is very throttle sensitive.
    Have been told that it most likely has a loose cylinder liner that is now clicking up and down?
    Jeff
    yes and no...
    not likely in a brand new motor...
    given that they havent made one for ages.
    yes, over heating it can loosen the liners as can prolonged full load operation
    mike 90 RR Guest
    Just a thought ...
    Another part to look at is a worn rocker
    Mike
    Jul 2008
    If a liner is going to move, the time when the noise will be most noticable is when the engine is cold and first started. Once up to temperature, the block expansion will hold the liner still and the noise will no longer be evident.
    I would lean towards worn lifters / rocker assembly as being the most likely cause.
    Ron.
    CROMER, NSW
    sounds like pinging to me.
    get your timing checked.
    once the sleeve slips, it stays where it ends up, it doesn't bounce up and down even when cold.
    LAND ROVER;
    HELPING PUT OIL BACK IN THE GROUND FOR 70 YEARS
    CARS DON'T GET ANY "GREENER" THAT.
    May 2008
    Romsey, Victoria,
    Ron,
    Cam, Lifters, and rockers & shafts were all brand new 20,000k ago. I have had the rocker covers off and checked all including bolt torques).
    I have got the motor bloody hot twice over the last 12 months through water pump corrosion.
    Definitely not pinging, and much louder and more serious rattle than pinging.
    I have bought another block off E-Bay and plan to transfer all parts into that.
    Will be pulling off the suspect side head first though,
    Many Thanks
    Jeff
    mike 90 RR Guest
    Quote Originally Posted by MoodyBlue View Post
    Ron,
    On the Suspect head side ..... ... Start motor .... USING a hose for listening to your ear ... Identify the position of the rattle
    Take the rocker cover off.....
    I'm still going for a dud rocker .... Have a real GOOD look at the depth of the (push rod) ball sitting in the hollow of the rocker // (Compare it to the others)
    Mike
    Jul 2008
    Hello Jeff,
    Were the parts that you used, cam, lifters, rockers and shafts genuine Land Rover items or Britpart pattern parts?
    I have heard of the latter failing in a very short space of time, with the distance that you have covered since fitment being more than adequate.
    Ron.
    Quote Originally Posted by RoverP6B View Post
    The other way around. Aluminium expands at a great rate than steel thus expands away from the liner.
    A hole in a block increases in diameter when hot, not the other way around.
    Avoca Beach
    X2.
    I didn't want to dispell dreams.
    Also IMHO the sleeves do move when hot and the movement up to the head and down to the ledge is what makes the noise.
    The gasket does not cover the sleeve so there is 30 thou or so to move plus the distance down on a composite gasket engine.
    Regards Philip A
