Results 1 to 10 of 11
Thread: Ignition wiring question Defender 2000 model.
    Oct 2008
    Does anyone know in which position the following four wires connnect to the ignition switch. The switch has 5 terminals of which 4 have been previously used and the following 4 wires are nearby after replacing the firewall.
    1. White wire with white plug.
    2.Brown wire/white tracer with black plug.
    3.White wire/red tracer with red plug.
    4.White wire/oranger tracer with green plug.
    Any help would be great.
    Thanks Ben
    Oct 2008
    Hi guys,
    Just wonder does anyone know in which position the following four wires connnect to the ignition switch. The switch has 5 terminals of which 4 have been previously used and the following 4 wires are nearby after replacing the firewall.
    Thanks Ben
    Oct 2008
    hey Guys
    just wondering does anyone know in which position the following four wires connnect to the ignition switch. The switch has 5 terminals of which 4 have been previously used and the following 4 wires are nearby after replacing the firewall.
    Thanks Ben
    Bendigo
    Hi, I have checked on my 99 TD5 wiring diagram here is what I came up with.
    1. White wire with white plug. runs to your ignition eg. , ECU,
    2.Brown wire/white tracer with black plug... positive from your batterie
    3.White wire/red tracer with red plug. Runs to start relay (R102)
    4.White wire/oranger tracer with green plug. cannot find that wire on my schematic, but is must be for
    your acceseries , radio cigar lighter etc
    hope this helps
    Matt
    Oct 2008
    Thanks Matt,
    Would you happen to know which wires go where onto the ignition switch as I have no record of how they were connected. Also do you know where I can obtain a wiring diagram as Daveshop doesn't carry any for that model.
    Thanks Ben.
    Is there any significant difference in the wiring diagrams?
    I could have sworn I'd given Dave (Incisor) a copy of the later RAVE with the Defender 1999/2002 supplement.
    Dave, have you got:
    RAVE: ..................................... V013
    Disc Part Number: .................. VDW103610(2)
    Quote Originally Posted by matt39788 View Post
    1. White wire with white plug. runs to your ignition eg. , ECU, Sw posn 1
    2.Brown wire/white tracer with black plug... positive from your batterie SW Connections IN1/IN2
    3.White wire/red tracer with red plug. Runs to start relay (R102) Sw posn 4
    your acceseries , radio cigar lighter etc Yep, that's AUX and goes to posn 2 Aux (you'll find it on the Audio Systems page)
    hope this helps
    Matt
    The switch drawing is shown on the schematic
    Oct 2008
    Hi guys,
    Does anyone know in which position the following four wires connnect to the ignition switch. The ignition switch has 5 terminals on the rear of which 4 have been previously used and the following 4 wires are nearby hanging loose after replacing the firewall.
    Thanks Ben
    __________________
    Ben, how many times have you asked this question in different sections? It has been answered already. Go back and read them.
    I'm merging all these threads.
