Results 1 to 10 of 26
Thread: Assist P38 to stop overheating ?
    Aug 2008
    Nth.Tasmania
    it has been mentioned many times here that P38's have a proclivity to overheat. as i understand it, due to the factory thermostat being set at 96'C., and blocked radiators. once overheated the engine is basically 'cactus' due to slipped liners etc. then big $$$$$'s to fix
    so i had the radiator serviced and will keep it so.she's off the road [and has been for awhile] till we get the codes sorted for Faultmate diagnosis to reset the new Arnotts GenIII.,opening up exhaust, bigger injectors,new leads/plugs,service compressor/valves, dual battery system [Odyseysx2],new filters,low profile bars fr/rr,underbody protection.
    in talking to my mate/mechanic about the thermostat, he suggested some options, drill some holes in rim of existing thermostat or put one in that opens at a lower setting. i should mention these blokes are very good knowledgeable mechanics and have/still do a lot of racing, circuit and speedway.
    what are your thoughts re thermostat and keeping temps down ?
    Ringwood VIC
    Ron has put a 3.9 Thermostat in its original location in the manifold, and has purchased a alluminium junction piece to replace the current thermostat. I heard recently that the reason Landrover moved the thermostat was to reduce the risk of cold shock in extremely cold area's such as canada etc. I was thinking about doing the same, but for the moment will use the current setup.
    Stu
    One can't remove the thermostat from the housing on a P38A so drilling holes in it or replacing it will be a tad difficult.
    However, help is at hand. When Davis Performance Landys rebuilt my 4.6 thjey fitted an 88 deg C thermostat in the standard position for all previous Rover V8s and I fitted one of these straight-through sputniks in place of the thermostat housing. It was purchased from Davis.
    See also this thread: RangeRovers.net • View topic - Possible to Change Location of Thermostat?
    Aug 2008
    Nth.Tasmania
    fantastic, geez you blokes are good, just read the link. thanks Ron will pass the info on and if you'd be good enough to post a phone number for Davis Performance Landy's i'll get one ordered and posted.it's gunna be a coupla weeks before she's on road, got a holiday coming up next week. holidays and owning maintaining a P38
    thanks again.
    ...............tasi
    233 Annangrove Rd Annangrove, NSW 2156 - (02) 9679 1978
    johnlamont Guest
    Thermostats
    Cleanliness of the cooling system is vital to ensure that overheating does not take place irrespective of any other factor. If your vehicle is not subject to emissions testing I would opt for 80 degrees if that could be shown to increase reliability, otherwise just keep your radiator clean. Removal of the top and or bottom tanks and a professional clean followed by new coolant would be a must for any engine if the slightest doubt persists about the situation. John
    80 deg C might be too cool for the engine management system.
    I tried getting a P38A radiator cleaned but the radiator shop said they couldn't get the crimping thing around the header tanks.
    Aug 2008
    Wagga
    Hey Ron,
    Is there any information about faulty water pumps that you know about. i replaced the radiator and thermostat and the car still got hot on those nasty days before the weather started to cool down but i didn't get enough time to test this a little more and since then it has been perfect. Talking to my mechanic he said that it could be that the impellers which are plastic in the water pump and if worn wouldn't pump enough water around? Just wondering if anyone has heard anything like this before.
    Remy
    Dec 2008
    Victoria
    For the potential damage which can occur and to avoid it I'd suggest looking at the water pump as a consumable/maintenance item.
    Avoca Beach
    I am not an expert on 38A cooling but I would like to make a couple of observations.
    1 if you drill holes in a thermostat the car will never warm up on a cold day.
    I once went to Katoomba in winter and the car went cold. Went home and pulled the thermostat and it was not fully closing, just by a tiny crack.
    2 80c would almost certainly be too cold for the injection. Maybe 88C would be OK , but you would have to monitor it and maybe read up on the specs of the GEMS or Motronic. If it is a Bosch, call Bosch technical assistance. That will challenge them! If GEMS, email GEMS in UK.
    3 the reason for the bypass thermostats is to reduce pollution to meet the later stringent regs, as most pollution from an engine is just after start up and warm up. The bypass thermo is also the reason for the Freelander 1 disasters.
    BTW there were a lot of recalls on early 38A, because the top rad hose was above the rad and airlocks formed. LR tried 4 or 5 different designs.
    Make sure you have one of the later top hoses. Also early cars used to blow heater hoses because of poor quality. Had one happen to a car in our club on an off road trip to Mt Airlie. AFAIK it was these issues that caused most grief to early 38As, as they would overheat and bye bye engine.
    It is possible to machine a hole and fittings for a thermostat housing on the front of a Thor manifold as I have done it, but mine is on a V belt engine so I do not know if there is enough room on a 38A. if GEMS it should also be possible .
    Regards Philip A
