Sorry - I dont know the answer to your question. But I assume it would mean the replacement of the head unit with one with bluetooth capability.
Can I ask why you are after bluetooth functionality (phone, mp3 etc)?
Folks,
does anybody know if the Bluetooth integration can be retrofitted by a dealer or can it only be done during the factory build?
Peter
there is a LR option on the D3 for blue tooth integration through the HiICE sound system and nav display.
It is for mobile phone use.
Do you have the base stereo or premium?
premium HiICE & the SAt NAV system
I think the bluetooth ability is limited then. But some have done some amazing hacks.
Check on dico3.co.uk in the 'in car electronics' section:
DISCO3.CO.UK - View Forum - In Car Electronics (D3)
The dealer fit bluetooth function can be fitted to all D3's/Spt's regardless of head unit.
You do NOT get full function of the system.
You cant dial from the head unit if u had a 9 button stereo.
But u can (up to 08my) store numbers into the system via your voice.
This system will keep voice numbers (up to 12) in the voice ECU, u can then ask system to "Dial Mum" & it will dial. Then when finished "End call"
The system is intergrated into your stereo, so the sound comes via speakers, it obviously mutes when you are receiving a call.
Good system, but expensive.
