Results 1 to 4 of 4
Thread: Regarding the new Brake Vac pumps
    Qld.
    Hello Folks,
    Got my Defender back from Southside today - it required a new Brake Vacuum pump.
    I see I have part No : LR012183. Looking in the sticky section, it seems there is an update to the service bulletin regarding this issue. It states that a 2nd replacement pump has been issued - part number LR006782.
    So has Land Rover replaced my 1st generation dud pump with the 2nd generation dud pump rather than installing the 3rd generation revised pump?
    2007 Defender 110
    1993 BMW R100LT
    dmdigital's Avatar
    I suppose I should look at mine and see if its got a part number on it, then I'll know if my 08MY Puma has the 1st or 2nd generation pump on it.
    Brisbane,some of the time.
    I will get junior to look at his & try & see the number of the pump he has.Half the fun will be trying to work out which thingy it is!
    We took it down to Ormaeu for a careful run on the weekend,& it comes out of CDL all by itself
    The leaver seems to move across & then the light goes off.
    Anyway they can have a look at it next week when it goes in to have the chassis repainted.It looks like it was done by a two year old with a can of spraypaintsurface rust is coming through all over the place.
    The Wabco vacuum pump on the Puma does not have a part no. on it.
    It does have the following numbers on it,if they mean anything to any one?
    914 004 005 k
    yciq2a451ag 14A09
    Have no idea what they mean,last one may be date code?14th,A for january,09 for year......?
