Results 1 to 10 of 27
Thread: County rear x member, from scratch..
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Talking County rear x member, from scratch..
    Hi all
    We have been planning on making a new rear-cross member for the county for a while now
    The one on it now is pretty well rusted out and a couple of weeks ago we bent it trying to get up a hill we shouldn't have tried
    Plans are to build a whole new rear x member, wheel carrier and tow-bar system then get it hot dipped galvernized
    Dad started on it today...
    tacked togethor...
    In the first/second pic you can see a square marked out on the bar that is where we plan to have a toung stile hitch-towbar
    Also plans are to have rear 1/4 bumperetts to protect the pannels
    TIM.
    99.87 MB
    Jeez, you guys dont stuff around! Love the work.
    What thickness metal is it? Looks a hell of a lot thicker than standard!
    Slunnie
    Oct 2007
    Thanks Simon
    Yep it's alot thicker then standard a combination of 4 and 6mm plate, going to be heavy but strong
    we got 55kgs of plate for $50 from the recyclers
    TIM.
    99.87 MB
    Quote Originally Posted by long stroke View Post
    Thanks Simon
    TIM.
    Nice! Thatll laugh in the face of physical mischief!!!
    Recyclers! I should check that out..... thats smart, one hell of a bargain.
    Slunnie
    Oct 2007
    They had all sorts of steel there, box section alloy, inch thick plate
    Steel is $1 a kg (sell and Parker recyclers)
    TIM.
    Oct 2007
    update
    Small update..
    Started on the towbar sleeve, dad couldn't find any box section to suit so he just bought some 8mm thick angle, trimmed it down and welded it togethor
    The tow-bar toung fits perfect, just have to make a toung with about a 6" drop so the trailer sits level with the car, something similar to a d2 one
    Pics...
    Just have to drill a hole for the pin then weld it in to the bar!
    square cut out in the cross member to fit the tow-bar..
    Gotta love the plasma cutter
    Might get more done tomorrow, but we have to many projects going at the one time
    CHEERS TIM.
    Singapore via Melbourne
    good work so far, engineering needed for the tow bar?
    now about all those milk crates... you got two choices - make me a new cross member for free or I makes some calls
    j/k!!
    Adelaide Hills - SA
    Very impressive!
    How thick is the original x-member steel? 2mm? It's going to be 10x stronger
    Oct 2007
    Quote Originally Posted by EchiDna View Post
    j/k!!
    Not shore if the tow-bar will need engineering
    Milk crates- dads been an x milko for about 2 weeks, forgot to take them back to the depot
    TIM.
    Oct 2007
    Quote Originally Posted by spudboy View Post
    Very impressive!
    Yep prob about 2mm
    Strong
    TIM.
