Thread: Removing Key In Chime
    Nov 2006
    Sunshine Coast and Brisbane
    This is what I have done to my own car and I take no responsibility for problems caused if people try this themselves.
    To anyone that is irritated by the key in the ignition chime when you open your drivers door I have a solution. The wire that I cut stops the key in door open chime but keeps the lights on chime and allows all the interior lights to work as they should.
    The wire to cut is the black wire that can be seen cut in the photo. It is located near the ignition barrel and has a black and cream wire going into the same spot on the plug. Once the black wire is cut make sure to put some insulation on the end as the wire becomes live when the key is in and I would hate for any problems to occur. Finally check that everything electrical still works and the key in chime is no longer.
    Nov 2008
    Ingleburn, NSW
    Did this today and worked great no more annoying door open chime!
    Old Bushwalker Guest
    I have been wanted to do this ages.
    Many Thanks
    Doing it today, only had the car 2 days and everyone is teed off with all the chiming and beeping (96 ES).
    PS previous owner has also disabled nearly all the security stuff cause it kept waking up all the neighbours!!!
    PPS also found out how to re-set circuits eg., rear wiper which had not worked for 7 years via the rear window heater/ignition process.....amazing stuff
    theborderdog Guest
    Just done this on my disco.........the silence really is golden.
    Adelaide Hills - SA
    That's a good tip - thanks.
    To the original designers, I'd like to say:
    Why did you not make a chime that stops after 20 seconds or something like that. Once you have been notified for a short period, no more is needed. Seems simple to me.... (Small rant over).
    Brisbane,some of the time.
    Now does anyone know which wire to cut on a late model hi ace.
    That chime is driving me crazy
    theborderdog Guest
    cut the red one then twist the purple and green together............ha ha ha ha
    Aug 2009
    lota, brisbane
    i have a 95 TDI and these don't work, so how do you reset them?
    Quote Originally Posted by THEBORDERDOG View Post
    That's exactly what i did,now does anyone know why the headlights don't work,& the horn goes when i open the glovebox?
    Oh,& it still friggin chimes.......
