Results 1 to 9 of 9
Thread: Ecu upgade,non flash to flashable.
    Williams West Aust
    Hi Guys
    I have purchased a NNN000120 ECU with a chip upgrade for my non flashable D2.
    Can those who have played with Nanocom in such a way PLEASE give a step by step how to change the ECU settings via laptop.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Ellendale Tasmania.
    Tombie2 or Pete from BAS would be the best guys to talk too I reckon, we are thinking of doing the same thing, let us know how you go Andy.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Williams West Aust
    Recieved my ECU today.Its a TRS item.Will look at swaping it over on sunday.
    Will let you know how I go with Nanocom changing the settings to suit.
    Andrew
    Williams West Aust
    REPLACING AN ECU (From the Nanocom Website)
    1.Read exsisting injector codes.
    2.Verify 2 or 3 track accelerator pot.
    3.Install new ECU.
    4.Read injector codes of new ECU with read setting,then modify with write setting to match exsisting engine,same for accelerator setting.
    5.Perform the Security Code learn to sync the alarm with new ECU.
    6.Write Map with Nanocom Map wizzard.
    Sounds EASY,unsure about writing maps,should already be done on the new ECU.
    Will see how it goes tommorow
    Andrew
    Andy
    I'm sleeping most of tomorrow due to night shift...
    But if you ring me early (before 8:30) or later (post 16:00) SA time, then I'm happy to discuss..
    Its very easy...
    Mbl: 0423 126 538
    Williams West Aust
    Well Ive done Brain surgery on Black Betty.
    She goes like a rocket but there are a couple of issues I need to fix.
    As it is a Defender ECU the SLABS and Turbo Modulator are disabled.The SLABS only seems to be stopping the temp gauge from working(the Nanocom is showing temp readings as per normal) and throwing an auto trans error(mine is manual and the new ecu is manual).The Turbo Modulator however is causing grief.Its going into full boost at 3000rpm then dropping all the boost in one hit,giving a missfire.
    Power is awsome,but not real driveable under full power.There is some black smoke,but nothing too bad.
    Anybody know if I can reset the 2 using my Nanocom.
    Mike I will give you a call.
    Andrew
    Williams West Aust
    Hi Mike
    Took a mate for a run after speaking with you.
    When the boost "hickups" boost remains zero on Nanocom,but still goes much harder than the standard ECU despite the boost being dumped down the exhaust!!!
    Andrew
    Williams West Aust
    Hi Mike.
    I contacted the bloke I bought the ECU off today.
    He has the same upgraded Defender tune in his D2.
    He has Autologic and will change the settings on mine to enable SLABS and the Turbo Modulator.
    Andrew
    Williams West Aust
    All done,Mike from Beechboro 4x4 who I purchased it switched the errant Defender settings with his AutoLogic.
    Drives really nice,like driving a different vehicle
    There is an issue to settle,my injector codes are all the same.He says mathmatically its possible,but he has NEVER seen one with 5 matching.
    See my thread on tuning a TD5 for some great info.
    Andrew
