Results 1 to 4 of 4
Thread: Idler pulleys
    Oct 2007
    Red Cliffs
    Idler pulleys
    Has any one the bearing numbers (codes) for the idle pulleys on the TD5 drive belt.
    Thanks Dennis
    Nov 2008
    i hope some one nose, i need new ones soon to the hole mount is 160 bucks, you can get pully kits for about 15$ ,, i can;t think of the name at the moment tho, there in melbourn, land rover import place,, heaps cheap,
    Normanhurst, NSW
    If they're oly just starting to squeal, you can remove them, prise out the plactic covers (without damaging them, clean thoroughly and regrease. I did mine about 20,000kms ago and they're still sweet.
    Do a search on odler bearings and should find some instructions and a few pictures.
    They are two different sizes on the Td5 and one of them is rivited into the pulley so is a PITA if you have to actually replace it, so I'd suggest that you get to them ASAP.
    Roger
    i replace the bearing in mine the othere week.. don't know the part number but the guys at LRA in thomastown new it and had it in stock... I replaced the rivets with pan head screws and nylocs i think. Replaceing the idler solved my altinator problems!!!
