Results 1 to 10 of 13
Thread: Dual boot, vista-W7RC
    May 2003
    On The Road
    so-----
    If I want to look at Windows 7 RC,,,
    whats the best way of loading it to not interfere with vista?
    does it require its own partition?
    how big? 15-20gb?
    does the release candidate download autoload?
    and can I tell it where to save/run?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    you download it, burn it to dvd and install from it
    havent dual booted it, i have it on a separate drive.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Adelaide Hills - SA
    I am running it as my 'production' client (even though it is build 7068 and classified as an Evaluation Copy), and have been extremely impressed with its stability and speed. Faster and 'snappier' than Vista (which I know is not saying a lot).
    Installed with a few apps (Office, etc - the normal client bits and pieces) it is taking up 19GB.
    Haven't tried dual booting. Didn't want to take a chance of messing up my 'real' production machine, so just installed to another drive.
    I am surprised you can still download it. I thought they cut that off a couple of months ago.
    Perth, WA
    I'm running a 3 boot option on my laptop at the moment, XP, Vista, or 7RC. My laptop has 2 physical hard drives, I have Vista on one HDD and XP and 7 on the other HDD, which is partitioned. You'd probably want at least 25GB for Win 7, just so you can load the odd application to see if it works.
    Tim
    Perth, WA
    Once you have loaded the second OS you will need to repair the Boot Loader, otherwise you won't have the option of which OS you want to boot. I used a program called Easy BCD, very easy to use, and you can change the name of the OS's, (otherwise you get stuck with "older versions of windows" for XP).
    Tim
    Oct 2003
    Montrose, Vic.
    Pedro, Windows 7 RC definitely dual boots smoothly with XP... cant see why Vista would be an issue.
    I had the beta dual booting with XP... removed it and installed the 64 bit RC for a while and have since moved to the 32Bit RC with no hassles with my XP build at all. ( I'm running it on my laptop - a Dell Precision M4300)
    Spudboy is right, its very smooth and snappy compared to Vista. I'm actually currently using it full time at work (in a 2003 AD) and its behaving perfectly.
    Tim, you dont need to use 3rd party tools to play with the bootloader.. BCDedit build itto the os does it all pretty smoothly anyway.
    Cheers, Mark
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Quote Originally Posted by Bytemrk View Post
    I'm sure that's what someone at Microsoft said once too
    Seriously though, is it any better than Vista? I understand it is supposed to load faster (wouldn't be hard), but has it still got the terrible interface?
    Oct 2003
    Montrose, Vic.
    It's definitely better than Vista. I tolerated Vista at work for about 6 months before losing it and rolling back to XP.
    It has a few little quirks that take some getting used to - but it is still only an RC too.. It's definitely built around the Vista architecture...but most of the annoying things that drove me away from Vista seem to be sorted.
    This I am actually enjoying using. Certainly worth a try. I work in a Microsoft based corporate network - so don't have the option to go Mac or Linux. But form what I've found so far I'll keep using it.
    Mark
    Mark
    Adelaide Hills - SA
    I reckon it's a lot better than Vista. I bought a new DELL laptop which came pre-loaded wiht Vista, and I "backloaded' to XP after a week. Slow as all get out.
    You have to get used to the new way the Win7 toolbar works, but that only takes a day or two. I'd say it functions more like Vista than XP, so if you don't like Vista you probably won't like Windows 7.
    My main machine is running Server 2008, and Win7 is pretty similar (apart from the new toolbar features).
    May 2003
    On The Road
    after a few days playing,,
    its PROBABLY faster,,
    hard to tell seeing it has NO other processes running,,
    I like the Library,
    I like the desktop photo rotation,
    you still have to agree to installing everything,
    is it better for me????
    hard to tell,,
    I'd need to duplicate my entire HD to see,,
    maybe there will be a cheap upgrade,,
    its only vista in a new suit after all,,
