Results 1 to 8 of 8
Thread: one hell of a smelly problem
    azz Guest
    hi all, i have a hell of a smell which i fear is a dead mouse in my heater if anyone has any tips suggestions or a way to deal with thids without taking the heater out i would really appreciate it .. thanks in advance
    Jun 2008
    Drouin East, Vic
    You might start by removing the heater inlet vents on the windscreen-wiper panel above the bonnet, I don't quite recall how far in you can access from there but it would be a reasonable starting point.
    azz Guest
    thanks i will give that a go i tried to get in via the vents in the dash but that did very little
    Brisbane, Inner East.
    A particularly unpopular Sales Manager at a mining equipment company I once worked for had an unbearable stench in his Commodore company car, so bad that the car could not be driven. Everything inside was pulled out looking for the source. Eventually a plastic bag of fish guts was found taped on top of the glove box under the dash.
    URSUSMAJOR
    It'sNotWorthComplaining! Guest
    Quote Originally Posted by Brian Hjelm View Post
    Those Yellow blocks they put in urinal trays crushed up and poured into the air grills on the older cars can make the driver's eyes water.
    Central Queensland
    my favourite is a plastic net bag filled with prawns/dead fish/diced snake jammed between the gearbox and floorpan
    also fun to pull hubcaps off and chuck a section of roadkill snake between the hubcap and wheel
    Apr 2007
    Mooroolbark, Vic
    I found a (hollow) dead rat between the air cleaner and the manifold. Never even smelt it... must have cooked pretty quick! The skin was like leather!
    Apr 2007
    Prospect SA
    Take the heater out and put replacement unit in is only way.
    Then get a ozone unit and pump that in for some time.
    Only way.
