Results 1 to 10 of 23
Thread: DIY bearing nut socket..
    Oct 2007
    JUST NORTH OF COFFS HARBOUR NSW
    Talking DIY bearing nut socket..
    I have been thinking of making a bearing nut spanner/socket for a couple of days now, so i decided to give it a go the sarvo, with dads help
    I wasn't shore where to post this thread, figured it wasn't realy a project or tut, so i thought general would do
    Anyhow this is where we got to..
    It's made out of 3mm plate
    It's a nice tight fit, just got to weld it up now, we were quite happy with the turn out
    CHEERS TIM.
    Barwite. Victoria
    I admire your initiative......
    I went to the hardware store plumbing section and bought one for $7
    Oct 2007
    Quote Originally Posted by Disco300Tdi View Post
    What!!!
    Yeah well ours cost nothing, apart from about 1-2hrs labor
    CHEERS TIM.
    Oct 2007
    officer, Victoria
    lol, all ranges sell them for about $20
    Oct 2007
    Quote Originally Posted by dirtdawg View Post
    And here i was thinking they were rely hard to come by
    Jock The Rock Guest
    Mine came in the back of my Landy when I bought the Blue Defender
    BTW did you know they fit the caps on Maxi-Drives? Thats what I originally thought it was for
    Upon saying that I do admire your idea, I was just thinking the other day as well. You see I need a light bar for roof spotties, and I thought yes got it, I'll find an old nudge bar and modify the mounts. I knew where there was one too. But it had gone
    But just now I had a bright idea wreckers are your friends
    SYDNEY -in the shire.....
    thats a nice tool........
    but it still needs to have a hole drilled through it on one end.......on the two opposite flats......
    so you can stick a bar through it for a bit of leverage........
    the locking nut needs to be done up firm.......
    im greek.......i use a hammer and chisel.......
    Oct 2007
    Quote Originally Posted by DEFENDERZOOK View Post
    Next will be some holes or similar, maybe something for a 1/2" ratchet
    We have also previously used a hammer and chisel
    TIM.
    hammer and chisel was we used to use in the dealership..........
    because we could never find the hub nut socket when we needed it......
    its easy to make a half inch ratchet fit if you can drill a half inch square hole.........
    otherwise......just weld a socket or similar in the end.......
    but just a simple pin through it will do the job.........you can get it more that tight enough with a screw driver stuck through it.......
    the lock tab will stop it all from coming undone........what youve made so far is perfect for the job.......
    Oct 2007
    Yeah the ones i've seen are just the simple screw driver through the holes
    But we are now thinking of cutting it in half and getting 2 out of it, it would probably be abit hard for the screw driver method when it's half the length it is now could be wrong
    TIM.
