Yes it will be the HP fuel pump. The whole fuel system including injuctors needs to be replaced.
Known issue with MY07 onwards with the first of the higher pressure pumps.
It should be under warranty. If it belt is not tensioned properly the bearings will shatter again and you need the lot done again.
Who is going to do your work?
  Reply With Quote Originally Posted by Diego Luego
