Results 1 to 10 of 11
Thread: Puma engine warning light query
    briann Guest
    My 09 Puma now has 20000k's up. It has had the standard vac pump warranty change at 10000km and a rear diff pinion oil seal change (also under warranty). Otherwise performs very nicely.
    Today about 20 secs after a cold start (still in 3rd gear) the engine coughed and seemed to miss a few beats plus seemed to "diesel" quite loudly for about 5 secs. The amber "malfunction indicator lamp" came on and I pulled over and shut down. After 20 secs I started up no problem and drove the 20km home with no problems evident. However the amber light stayed on.
    Anyone had anything similar?
    I am in Newcastle so nearest dealer is in Sydney.
    Now that Alto has shut here does anyone know if there is a CPU diagnostic unit for the Puma available in Newcastle?
    Brian
    Jul 2008
    Try All4x4 at Kotara, if anyone has they will.
    This sounds like the noise a lot of owners are experiencing. Dullbird has posted an extensive thread on here somewhere. Seems to be no fix yet.
    Jul 2003
    It is most probably not a major issue. We have become a little paranoid since Dullbird and Muddymech's unfortunate and real experience with theirs
    Maybe just some damp in the fuel system...cold humid weather. The fuel pressure sensor on the fuel rail may have had a hiccup.
    Happened to mine under similar circumstances.
    I've heard that the light will go out after a short while.
    I also read that undoing the sensor on the rail (there is a yellow release button on it) and giving it a wipe with a dry cloth might help.
    Reading the fault code will probably only confirm that the sensor has picked up a fault.
    Mahn England
    Ex 300Tdi Disco:
    Adelaide Hills - SA
    briann Guest
    Quote Originally Posted by one_iota View Post
    Thanks Mahn. So far (having done another trouble-free 20km from cold) the engine light is still on. I guess if was going to reset it would have by now?
    Brian
    Perth, WA
    It usually takes 3 driving "cycles" to clear a fault, so long as the fault itself is no longer present. I'd still give your dealer and LR assist a call though.
    Tim
    briann Guest
    New evidence has just been discovered
    Quote Originally Posted by TimNZ View Post
    Tim
    Thanks Tim.
    I have just followed Mahn's tip re the sensor (except it did not appear to be a sensor)and the engine light cleared immediately.
    At the rear end of the common rail there is what could be an over pressure relief valve. Attached to that is a small-bore plastic pipe with a red quick release clip. I pulled it off and it dumped about 1 cc of diesel. After reattachment I started up and engine light is gone. http://www.aulro.com/afvb/images/smilies/angel.gifI am a bit baffled as I cannot see any electrical sensor connections in the area??http://www.aulro.com/afvb/images/smilies/angel.gif
    My guess (and I am hoping someone can provide some real knowledge) is that the over-pressure valve lifted briefly and that the released diesel is sitting on the sensor keeping the light on.
    Any better ideas?
    Brian
    I love this forum - in the old days we would have been flying blind - mind you they hadn't invented CPU's then and stuff could be fixed!!!!
    Jul 2003
    Brian,
    Something seems to have worked.
    I think of this as being a cross between reading a goat's entrails and bush mechanics with a dealer as our witch doctor not knowing much more but having a gadget.
    There must be a rational explanation.
    Mahn England
    Ex 300Tdi Disco:
    JohnR Guest
    We had a similar thing over a year ago with ours on a cold morning, I pulled 3rd gear too early, rattle rattle thump thump, little amber light and as TimNZ said after about three drives it went away. I took it to LR anyway and with their little magic tool they decided it was a sticky EGR valve? They swapped it under warrenty, never had the problem again
