My 2000 mod disco 2 had a bloody great rubber boot which was removed and wires run through. What is you veh?.It looks like a hole saw jobbie(and some bog)![]()
Hello,
I have just received a very quality bit of kit from drivesafe-the headlight loom upgrade kit. However, I have a query regarding installation. I have spoken with drivesafe about this and he has asked that I post this in a public forum. Please note, this is a quality bit of kit and all connections, wiring, etc. are top notch!
Ok, the problem is that I need to run 2 plugs (6 wires) to one headlamp and 1 plug (3 wires) to the other plug. The instructions for this are simple and there really isnt any way to screw it up (famous last words?). However, on the back of the headlights is a metal "cup/bucket" that only has one small hole in it where the original wiring is routed. There are no other access points to the back of the lamp where the cables need to terminate. I really dont want to make a massive hole in the side of these sealed "cups/buckets" that then has to be sealed.
I am keen to find out how others have done this as drivesafe has informd there are a number of these kits installed on Series II vehicles.
The first picture shows what I currently have and the second shows the plugs which I need to get to the back of the globe.
Thanks in advance for your help!
Please see the pictures below:
..........mine is a 71 IIa. Nothing much rubber on the back of the headlights on this one!
I am sure someone has done this before and can shed some light on this.
Cheers!
I have not done this to my 2a but I plan to. However, because the kit is not directly suited to the 2a, I will not be using the kit itself.
The first thing you have to decide is whether you retain the original lights (assuming they are still fitted) or change to ones using H4 bulbs that fit the sockets supplied in the kit. If you are retaining the existing lights, you will have to join the new wiring to the existing bulb sockets. I would do this outside the headlight dish, but not knowing Traxide's colour scheme, I can't tell you which wires to join. If you are planning to use H4 type bulbs which suit the supplied socket, I would run the wires through the existing grommets, cutting and rejoining them as necessary - the only wiring inside the dish should be the bulb sockets.
Hope this helps,
I rewired my IIA myself when I built it many moons ago. I ran 6mm diameter wire for all head/tail/stop lights (overkill I know - but I have ~0 voltage drop). I installed H4 bulbs/headlights, cut the grommets as JD suggests, and ran separate wires to each light from the relays (no way I would have been able to get 6 wires through the grommet.
I didn't bother resealing the gromets - with such thick wire they seem to still be relatively water/dust-tight
cut and shut the wires to suit your perpose still may need a little triming
It must be a very early 1971 as most of them had the headlamps in the mudguards.
I have upgraded the headlamp wiring in most of my Land Rovers, however in this case I would be doing the terminations outside the headlamp bucket.
There are 2 options,
- either replace the nice fittings on the kit with bullet connectors and patch in as if you are doing it on the lamp.
- or remove the original wiring from the bucket ( you will find three bullet connectors usually in front of the radiator) and pull the bullets through the front of the bucket, then if you can remove the individual terminals from the plastic fitting that goes on the headlamp bulb push them through from the back, add an appropriate rubber grommet and insert the connectors into the little black plastic terminal holder.
Diana
John,
The kit comes with plugs which fit my headlamps, so that isn't the issue. The H4 kits I have seen only change the reflector. The bucket piece wouldn't change at all, so I am in the same situation whether I go with an H4 upgrade or not.
I guess the best way to proceed is to pull the original wiring through the grommet and then try to replace this with the new wiring. Of course, this will require me cutting the plugs off which isnt the biggest of issues. I am sure I can arrange a couple of more from drivesafe.
Diana,
I have been told that the late IIa military versions maintained as many features to previous IIa versions so as to reduce the need for the army to carry parts for two models. I'd say you are spot on about how to proceed with getting the wires in. I dont like my chances of getting the grommet back in, but then I guess that isn't really going to be such an issue.
Thanks everyone-Ronnie
If those plugs fit your headlamps, then your headlamps are not original (assuming it was the same as my 1970 one). Rover changed the headlight fittings after suffix A, but PMC retained the older Lucas prefocus type bulb for quite some time, possibly until the end of S2a production as part of the Australian content. Many of these have been replaced by either sealed beams or other later lights that use the 3 pin socket in your Traxide kit.
Diana - my 1970 ex-army 2a also has the headlights on radiator support panel, but it is clear from the amount of spare wire that the wiring harness was intended for headlights in the mudguards. Whether this was changed at the army's request during assembly or was a field conversion to use available bits, I have no idea.
I knew Uncle Ho had explained this to me previously........Below is what he previously shared with me:
:I can't recall how many were built, but I do remember the fly leaf page in the front of the master book, which stated that vehicles which were destined for South Veitnam were to be fitted with the earlier type 2/2a radiator support panel and guards as well as associated wiring, this was for vehicles need to bring the vehicles up to Estabishment, I would say that it would have been 100-150 I don't think it would have been more. I was just to keep parts commonalty with was was in SVN stores, It was just one of those things that were in the front of the Master Parts book along with all the single page updates of part numbers and the P/n changes, even in the 60's it was chaos in the parts and production sections, more bosses and paperwork than was necessary" ---Thanks again for the info!
John, the lights have definately been changed then. It must have been done quite some time ago as it was done prior to the previous paint job. Hopefully this will make my life a bit easier......My plan is to just upgrade the wiring at the moment and then if I feel the need I can put in the H4 reflectors and bulbs in the future.
