Results 1 to 8 of 8
Thread: 08 defender drama
    Question 08 defender drama
    my mates new defender with 7500ks has masive oil leak under bonnet he has taken it to mechanic and has been diagnosed as oil pump leak aparently all ford transit motors fail the same way this is really bad news for him as reliability is aworry when he goes into the pilbara bush gold prospecting anyone got any ideas or had the same drama
    Hi! This is a known problem and there has been substantial discussion on this here. The search function should get you there.
     2005 Defender 110 
    Qld.
    It's no real drama - not in LR terms anyway! Its the brake vacuum pump - the seals go, leaking engine oil. The brakes still work! All you need is top up oil to get you to the dealer - they replace pump with modified version so this won't occur again.
    2007 Defender 110
    1993 BMW R100LT
    If you go into the defender section you will see there is a thread in the sticky section that has all the recalls and bulletins for the 07 defender onwards. the vacuum pump is in there with the relevant part numbers etc
    Padstow NSW
    oh and welcome to pumasville
    cheers phil
    Adelaide Hills - SA
    I must be about the only person with a Puma who hasn't had this done yet. Hope it fails before the warranty runs out (mine is an '07).
    One bloke I know has gone through 3!!
    Can I get it changed if it is not leaking?
    I believe you can get it changed if you express concern or at least thats what I think it says in the bulletin...go have a look
    Quote Originally Posted by spudboy View Post
    Mine's still the original. Yes you can get it changed, but then the issue is the changed one may go if its not the newest model unit. So I'm working on the theory that if it isn't broke, don't fix it. I did think of carrying a spare, but didn't get around to it.
