Results 1 to 10 of 27
Thread: Recovery points for Series trucks??
    Aug 2008
    No problems at the back - a decent rated shackle through the towing tongue is fine there, but what to do at the front?
    I have a bumper made out of 6mm thick parallel flange channel. but it has the same 4 mounting bolts as a standard bumper. I`ve used one of those 10000lb rated hooks with a spreader plate behind it (bolted to the top of the bumper, but these make me a bit uneasy - if the bolts holding the bumper go, then someone is going to wear 25kg of steel...
    The pommie mags all show those swivel recovery points, mounted flush - is there a locally available alternative to these? and wouldn`t they also only be as strong as the mounting bolts (bar to chassis)?
    Pictures would be appreciated...
    Not that I ever get stuck and need recovering, but on I occasionally help owners of lesser vehicles when they can`t keep up with me...
    Jock The Rock Guest
    serpintine wa
    they have d shapedrecovery points ontop of the chassie with 4 bolts on both sides like this
    ps im also after some
    Melb. Vic.
    Quote Originally Posted by Jock The Rock View Post
    Geepers Jock,
    I missed that thread altogether - I want 4 .
    Where did you purchase them from I may go for another group buy.
    MickS Guest
    I bought one pair for the front of Basil and will mount them on the bar in line with the chassis rails...Thanks Jock....What is the best rear recovery point for a series II?
    Jock The Rock Guest
    I'm not really sure on that one sorry
    They don't have the Hayman Reese hitch which makes it a bit difficult
    Sorry
    Jun 2007
    Oatley, NSW
    This was my solution to the front recovery point problem. Hope it helps:
    Series III Stage 1 with a bit of a difference
    Stirling
    loop a chain through the spring and up and over the top of each chassis rail.
    join with a big shackle and you wind up with something like this
    I used 2x 1.5t bow shackles to join both sides of the chain to a 3.5t bow shackle in front of the upright.
    1 per chassis rail with a bridal strap.
    series Recovery point complete.(works on all leaf spring suspension that has the spring shackle at the outer most side of the chassis)
    total cost $25
    Jun 2003
    Launceston, Tasmania
    I've got the standard shackle mounting brackets held on with 4 grade 8 ht bolts. seems to work well for everything I have given them to do yet!
    1994 Discovery TDi
    2004 Discovery 2 TD5
    2010 Discovery 4 TDV6
    Grover looks the goods! Does anyone have pics of rear recovery options/pics for the Series?
