Thread: Air intake modification
    s851 Guest
    Hi all
    Is there any major problem with replacing the whole oilbath filter and hose assembly (2.25 P S2A), with one of those circular air filter units (with a reputable air filter installed) directly on top of the carby?
    This setup will only be for city driving, when going into dustier environments
    i would reconnect the oil bath.
    WA
    I have a hilux filter assembly on mine, fitted into the LH guard.
    A (correctly sized) cellulose fibre (paper) air filter will be more efficient than the oilbath. There is a reason they aren't used any more.
    As isuzurover says, there is no reason not to use one, although you may find the clearance under the bonnet limits your choice of filters unless you use a remote one as he suggests, and provided the installation is airtight and the element of adequate size.
    and you'd want to do this because?
    s851 Guest
    Smile
    ok sounds good, thanks
    Boonah, QLD
    Has anyone put a snorkel on a Series? would like to know about it
    seems there is plenty of room next to the firewall on the LH side to fit a remote air box but don't know about a sorkel as I like to fold my windscrene down on a regular basis...
    WA
    Quote Originally Posted by Newbs-IIA View Post
    yes.
    If I ever wanted to fold the screen down it would take about 2 minutes to remove the snorkel (2 screws, 1 bolt and a hose clamp).
    There is a hilux filter housing squeezed into the spot where the heater would be on a SIII.
    East-South-East Girt-By-Sea
    1.20 MB
    Ben
    Has the RAEME RSM ever put you on report for damaging a military Land Rover?
    Diana
    P.S. Newbs IIa: Snorkels have been optional extras for Land Rovers since the 80" model.
    Near Seven Hills, Sydney
    Ben
    Diana
    Still manages to pose for the BEST pics shown on this forum bar none
    Ben, please think of me when writing your Will
    Great looking Landy
    Mark
    WA
    Ben
    Diana
    I think you meant to say "improving"
    Given the modifications done to it in Vietnam, I don't think they have a leg to stand on:
    It was basically a rolling wreck when I bought it, as it had been neglected as a shooting hack then badly rolled by the previous owner. But the panels are all original, I painstakingly straightened them all - even though the sides of the rear tub were caved in about 12" in the middle on each side.
    It is badly in need of a respray though, and I am contemplating returning it to olive drab.
    Quote Originally Posted by longing4alandy View Post
    Great looking Landy
    Mark
    Thanks for the kind words Mark. Should I ever decide to part with it you will be the first to know!
