Results 1 to 4 of 4
Thread: ROSIE
    Nov 2008
    ROSIE
    Picked up a new mate (and organ donor) for Arfa yesterday - both '55 86s with serial numbers only 139 apart, found and 'saved' about 10 km apart.
    Is there any way of tracing their original export and dealers/first owners/anything else from these numbers on the bulkhead plate? - 57661371 (Arfa), 57661232 (Rosie).
    'Rosie' has had a hard life - chassis and bulkhead a total mess but a enough useful bits to be interesting.
    She once had a canvas top - windscreen 'teeth', bonnet supports, door surrounds and other fittings remain.
    Also rear grab handles mounted inside the tub rather than on the capping - I suppose this worked better if a hardtop was fitted sometimes.
    The other odd thing is a panel directly in front of the grille panel, between the wings. I have never seen these on a SI so assume they are from a SII, but same layers of paint as the rest of the body so must have been there a good while. Is there any chance this was an original fitting?
    She has what I take to be a later 2.25 engine (confirm from pics?), stromberg carb and fuel pump at the tank end (I think). I'll probably try to swap this for some other SI parts one day - unless there are enough engine parts in common with mine (2L spread bore) to keep it for spares - can anyone advise?
    Also threw in a pic of the steering wheel - the rim's finished but centre with switch are intact - just needs a horn button. Maybe worth restoring?
    Here's some pics, anyway. Don't you love driving home with a new SI grille looking in the back window?
    D
    South Australia - Port Pirie
    Hi there
    Many thanks for the pictures........
    I agree...........but they look better on top of the tub.
    As for:
    I am not sure....
    All the best
    Wayne
    Thumbs up
    nice find there! its in good nik. I love the air filter........!
    NSW, Australia
    Yep - 2.25 with aftermarket racing airfilter.
    Looks great!
    [B][I]Andrew[/I][/B]
    [COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
    [COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
    [COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
    [U]1995 Defender 110[/U]
    [SIGPIC][/SIGPIC]
