25th July 2009, 04:45 PM
Relay clicking when depressing brake pedal
I have just finished wiring the electric break controller on my Disco3, and have noticed while sitting in the driveway and depressing the break pedal I can hear a relay clicking and can feel the click also under the auto gear stick. Cant say I have noticed it before.
Can anyone confirm if this is normal? I tried disconnecting the plug from the newly installed controller, but made no difference. I installed as per instructions given by sniegy in another thread. Just hope I put the diode in the correct place.
Craig
25th July 2009, 05:10 PM
I don't know the setup for the brake controller, but it it normal for relays to click when they make contact as they are essentially a swich. My experience is that heavy duty relays will also generally be louder.
25th July 2009, 05:20 PM
I don't know the setup for the brake controller, but it it normal for relays to click when they make contact as they are essentially a switch. My experience is that heavy duty relays will also generally be louder.
25th July 2009, 11:25 PM
#4
Don't you need your foot on the brake to get it out of park? Sounds like that would need a relay.
Cheers, Steve
25th July 2009, 11:49 PM
#5
Yes your probably correct... just paranoid as I have not heard it before and noticed it after I had finished all the wiring.
28th July 2009, 09:03 PM
#6
OK you got me! Read the post - thought I haven't noticed anything like that.
Tried tonight when I got home. Definitely feels like an actuator for brake and getting out of Park. I could only feel and hear it if I was in park or neutral.
Of course now I can hear it even if the radio is at full bore.
Mike
