G'day All, Good one Gary, it's always good to get to the end of the road 'kinda sorta' LOL cheers mate Dennis![]()
Well after 18 months of slow progress, Miss Piggy finally went in for her roadworthy and LPG cerification. The mechanic did some head scratching and the other mechanics all got there cameras out but common sense kicked in and they decided to treat the 101 like any other car.
Result - 100% pass.
Here tester is taking Miss Piggy for a drive and the brake test.
Arriving back after a successful test.
They noted the vague steering and went over it quite carefully but noted that there was no slack in the system.
$1200 later - number plates and 12 months rego.
The LPG system is still a bit of a worry. I drove for 50km yesterday on LPG and it worked well but the engine would not idle when you pulled up to lights - it would stall and would not restart on LPG and I would have to start on petrol. Yet - in my driveway it idles quite happily on LPG.
On the way to the roadworthy the truck was missing on LPG and the mechanic said the thingy was freezing up - not getting hot water. But the day before it all ran fine - then I realised I hat the heater on - the LPG installer had used the heater pipe to get the hot water for the LPG - now that I have the heater working properly (noting there was no heater when I bought it) when I turn off the tap the LPG also gets no hot water. Not an issue at the moment as I can keep the tap cracked open a bit but I will have to look for alternative plumbing for the LPG.
So the 101 is on the road, I will replace all the oils and fluids over the next few days and then wire up some lights inside. The 101 ain't no speed machine - cruises at 80kph indicated - 75kph GPS - on a freeway 100 should be OK. Yes I do have the 101 rumble and it is bad when it happens but easy to drive through.
Later the overdrive will be going in, then the rear diff lock and then the front diff lock. Then turn the mind to things like improving the brakes and steering.
So I am on the road
Congratulations Gary!
It makes all the blood and missing skin worthwhile. I know what it's like to get a roadworthy on a 101. I had to completly pad the rollbar to make the tester happy. Apparently I could hurt myself!
Enjoy.
Well done.
Time for some fun.![]()
Congratulations. Looks fantastic. I am very jealous.![]()
Very nice... great work![]()
EVL '96 Defender 110 - Emerald '63 2a Ambulance 112-221 - Christine '93 Rangy - Van '98 Rangy - Rachael '76 S3 GS - Special '70 S2a GS - Miss B '86 Rangy - RAAF Tactical 200184 & 200168
Fantastic news and I am happy for you as I think the last few weeks have been the hardest so far in the restoration.
You now need to get some miles in miss piggy to iron out any bugs.
Yes the cruising speed for a stock 101 is 8okph / 50 mph.
The 101 will go to 80mph stock ,.but the strain on vehicle and driver is not worth it.
It looks much better now with the canvass top on.
Regards ron
I also have 8 litres of olive drab in the garage so a quick paint job might be the go if I have time on my hands. Don't like the idea of the preparation though as the current paint is peeling - though if it looks OK from a distance that should be good enough.
I also need to put all the 101 stuff back on like the pintle hooks, rear bumpers, winch fairleads and so forth. Still quite a lot to do but at least it can be driven - an engine tune up will not go astray.
Thanks for all the comments.
Looks great Garry!
Congratulations!![]()
[B][I]Andrew[/I][/B]
[COLOR="YellowGreen"][U]1958 Series II SWB - "Gus"[/U][/COLOR]
[COLOR="DarkGreen"][U]1965 Series IIA Ambulance 113-896 - "Ambrose"[/U][/COLOR]
[COLOR="#DAA520"][U]1981 Mercedes 300D[/U][/COLOR]
[U]1995 Defender 110[/U]
[SIGPIC][/SIGPIC]
