Results 1 to 4 of 4
Thread: Tie rod End Warning
    Nov 2008
    Greenwood WA
    Tie rod End Warning
    Hey guys just referring to a previous post I made entitled "where do I get parts"
    In this post Diana warned me about getting the incorrect Tie rod ends.
    I have found some that have about a 1cm shoulder and it didn't seem as shouldered as the ones Diana (lots-a-landies) displayed in her picture.
    They are from Rovacraft in Perth and I was wondering whether it was worth buying them, they are $27.00.
    I don't want to buy if incorrect though.
    thx guys
    There are two types, ones which have the unthreaded shoulder, about 12mm wide, and ones with no appreciable shoulder at all. I have not seen any in between. And as mentioned in that post, make sure you ge the right ones, which on the 2a should be the ones with the unthreaded shoulder. If the clamping section of the tube has no thread, it must clamp on an unthreaded shoulder.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by matpoli View Post
    the important issue is not the length of the shoulder per Se but that the shoulder is completely below the clamp without any risk of the clamp slipping off the end of the tube. This could be an issue with the later folded clamp, but not really an issue with the Series 1, Series 2 and early Series 2a cast type.
    10 - 12 mm is probably O.K.
    Nov 2008
    Greenwood WA
    Thanks guys I ordered them from Rovacraft in WA, they take 4-6 weeks to get here from the UK so i'll just have to wait.
