Results 1 to 8 of 8
Thread: How to:
    Sep 2006
    Melb.
    How to:
    Just wondering if anyone has any tips for removing the dash from the 99 P38. I want to remove the heater unit to replace the globes in the heater switches, as both are both blown. I tried attacking it today but couldnt get the side plastic bezels off without knackering them
    Douglas Park, NSW
    You don't need to remove the dash for this job.
    From memory, the centre console side panels need to come off & maybe a couple of other bits of trim.
    Wander over to Range Rovers & I'm sure it's detailed there (with piccies too).
    Yep, we've written it all up. No need to remove the heater, etc.:
    See Fascia Switch Pack
    That page will give you links to removing the side panels, etc.
    Sep 2006
    Melb.
    Ron, I have the unit out, which globes are specifically for the switches that control the temp?
    Oops! I misread your post. Sorry!
    You need this page: LCD Backlight Repair
    The only bulbs you can replace are those accessible from the rear of the HEVAC control unit. See pics on that page. These should backlight the switches. The little LEDs that illuminate when you press the lower switches etc, are not user replaceable.
    Ron Beckett
    Sep 2006
    Melb.
    My LEDS are ok, its only the backlight globes for the Temp control, sick of stuffing around trying to set the temp at night cant see them. cheers
    Replace all four. 3 off 1.2 watt and 1 off 2 watt.
    My 1.2 watt wedge base globes could be replaced in the holders. I bought the globes at my local auto parts store.
    The 2 watt bulb was welded in to its holder.
    Sep 2006
    Melb.
    Thanks fellas, all sorted bought 7x globes (couple spare) $20 for the lot. Can now see all the buttons again
