                                                6th August 2009, 03:31 PM
			chipped defender performance
					Hi,
 Just curious if any TD5 chipped defender drivers have done
 a 80-120kmh time check in 5th?
 Or for that matter can anyone tell me how long a standard one takes?
 Giles
                                                6th August 2009, 03:57 PM
					i never did any timed stuff, but christ it was quick
 everywhere it was quick
 cheers phil
                                                6th August 2009, 05:58 PM
                                                6th August 2009, 08:22 PM
                                                #4
			performance
					Yeah mine is pretty spritely too with the boost box in now...
 I'm in perth.
 I timed mine the other day on a long run. 80-120kmh in 5th was 6.5-6.8seconds depending on my accuracy.
 Starting to flare the clutch a little so have backed the boost back dow a touch.
 Giles
                                                6th August 2009, 08:26 PM
                                                #5
					Yes,i've found the clutch to be the weak point, if my foot is so much as touching the clutch, i get slip.
 If ever I am replacing the clutch, I'll put in extra springs.
 Fraser
                                                6th August 2009, 09:22 PM
                                                #6
			clutch
					I dont even have to touch the clutch!
 What chip/mods do you have on yours Fraser?
 Giles
                                                7th August 2009, 08:42 PM
                                                #7
					We had our TD5 chipped by Jeremy Fearn,hell of a differance,will get the Puma done shortly.
