7th August 2009, 05:29 AM
73 Rangie Clutch Hiding Under Pedal
Hello All
After not driving the beast for a while found that the clutch seemed to feel different but got used to it then about 2 weeks later went to drive her again ( don't drive her everyday am not Richard Branson ) and the clutch is non existant . Is this probably a leaking Master Cylinder and just Bleed and fill and keep a eye on the level or the start of a Wallet Removal Exercise ?
Thanks Garfy
7th August 2009, 08:57 PM
is the master cylinder reservoir empty ? if it is is there clutch fluid leaking from the bell housing or down the clutch pedal ?
8th August 2009, 05:52 AM
Thanks Peewee
Got it sorted , the pipe at the slave cylinder was all bent up so replaced that and the put new fluid in and I have clutch , will keep a eye on it to see if theres a leak
Thanks Garfy
