Thread: defender vents
    malsgoing130 Guest
    defender vents
    Hi All,
    No I dont mean vent as in frustration or anger This may be a silly question, but how does one remove the forward facing vents. I have ordered new rubber seals and will need to install them.
    Mal
    JDNSW's Avatar
    Assuming they are the same as the older ones, the hinge pin is knocked out with a suitable drift - I made one by cutting the point off a four inch nail - and the two small hex head screws that attach it to the vent can then be removed (open the vent). Don't drop them into the dash - you may have a major job to recover them.
    The whole operation is done from outside, something to stand on makes it easier.
    malsgoing130 Guest
    thanks John,
    I managed to remoe it Ok (8mm spanner) and have replace the one seal NOT muc fun putting it back on
    Mal
    Oct 2008
    Also taking off the bonnet gives you a little more room.
    Ben......
    Perth W.A.
    mal i closed mine up for winter .....one has sealed shut tried opening it the other day no go ...will be ok when i change the bulkhead i'll just have to get new ones is all doah
