Results 1 to 10 of 13
Thread: Electric Window mod. for Puma and other LRs
    Perth WA
    Well, after tuning the key off and then realising that the windows are still down for about the millionth time, I decided to do something about it.
    A simple little timer circuit and a relay that hold the power on the electric windows circuit for a period of time after the keys is removed.
    I used one of these High Performance Timer - Jaycar Electronics from Jaycar and a standard 12V relay. The timer is in kit form so you will need some some basic electronic and soldering skills to assemble it.
    So then you have to rip the dash apart so you can access the rear of the fuse/relay holder. Remove the metal bracket from the firewall and then remove all the fuse holders and relays from the bracket.
    now we are having fun... Its normally about this time that the wife come out and asks why our $50,000 Land Rover doesn't have a dash board.
    Once you have accessed all the wires at the rear you need to connect up your timer and relay to the wires from the back of "R143 relay-window-lift" I wired my relay basically in parallel to the standard relay and took the input to the timer from pin 85.
    If anyone wants the wiring diagram I can make one up, but its pretty straight forward
    Then I just wrapped the timer in a plastic bag and some gaffa tape for protection. tidied up the wiring and put it all back together.
    Time taken... the best part of a day.
    Cost... less than $60 for parts.
    thanks for reading. Comments welcome
    Craig
    JohnR Guest
    Looks like a great idea, we always leave the windos down
    I know what you mean about having half the car ripped apart, something just feels wrong doing it to a new car.
    Feb 2005
    i need that setup for my mums corolla...........
    BM and I were only saying how we should look into something like this the other day. Good post and thanks for the info. Will have to wait a while before it gets on the list of things to do though.
    Perth WA
    as a side note...
    I would like to thank Derek for supplying me the Puma wiring diagram on PDF. I'm not sure I would have figured it out without that so thanks.
    Craig
    Dec 2008
    Quote Originally Posted by Craig View Post
    Craig
    Good bloody work. Why don't build one that winds the windows up when you hit the central locking button?
    as a side note...
    Craig
    That was nice of him
    Perth WA
    Wiring Diagrams
    Okay, here are the wiring diagrams for this project...
    First, the timer should be set into "one shot" mode and switching should be "high to low"
    This is the suggested set-up for the project...
    This is how mine is wired up...
    Then, as I said, wire the extra relay in parallel to the existing one, get your trigger (input) from the ignition wire. then just run some power and earth to the timer
    When the input switches from high to low (12V to 0V) the timer connects the NO (normally open) to ground until the set time has elapsed. then opens it again.
    I have mine set for 60 seconds. I think that is enough time to get out of the car and realise you have left the windows open, and still wind them up.
    If there are any Auto Electricians out there who can spot a problem with my wiring, don't hesitate to let me know.
    Have fun
    Craig
    Last edited by Craig; 13th August 2009 at 10:16 PM. Reason: to correct my awfull spelling
    Nera Donna Guest
    Rear electric windows?
    Question. Has anyone looking into converting the rear manual windows to electric ones. Just wondering?
    So what's the best way to get the dash apart, any tricks ? Also where can the wiring diagrams be found ?
    I want to do some wiring in the dash, but have not had the confidence to make a start , it still smells too new !
