Results 1 to 9 of 9
Thread: Brake/Stop Light switch
    Near Seven Hills, Sydney
    G'day all,
    What actuates the stop lights when you depress the brake pedal on series 2As? As long as I have owned it my vehicle hasn't had the rear lights hooked up, and when I had the pedal assembly out there was no electrical wires or switches anywhere near. Looking in the 4 manuals I have, I didn't see any reference apart from bulb type, and the circuit diagram showing a switch.
    Is it a hydraulic pressure switch, is the switch at hub level, or is mine missing?
    Signed,
    Confused in Carlingford
    Sounds like you have a hydraulic switch. Late 2a's have a mechanical switch in the cabin above the pedal. If you chassis number suffix is E or below you should have the hydraulic, which is in a junction down on the chassis below the master cylinder. If you follow the pipe from the master cylinder it goes straight there.
    Peter
    JDNSW's Avatar
    As Peter says.
    Thankyou Peter and John,
    I'm always happy to know something isn't missing
    -Mark
    Gold Coast QLD
    Quote Originally Posted by Smaug View Post
    Peter
    You just answered the very question I was about to ask. Thanks Mate
    Cheers Ian
    Thumbs up
    some of you may know already but i had to get a new brake switch for my RRC and found the exact switch at Super cheap auto for under $20 it has Lrov/Commdr labelled on it. cheaper than 4WD's and from UK.....! i think its th same as the 2a?
    Chris
    JDNSW's Avatar
    Quote Originally Posted by chris1983rangie View Post
    Chris
    Looks very familiar!
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Talking about mechanical switches above the pedal . . .
    Is it possible to install a pedal box, servo unit and dual brake cylinder from a Defender into a Series 2? Assuming that the brake lines etc got sorted out, is there anything to stop the bits bolting onto the firewall?
    Thanks, Peter
    JDNSW's Avatar
    Quote Originally Posted by peterg1001 View Post
    Thanks, Peter
    I have not actually compared them, but I think they will fit, the same as the late S3 boosted, dual circuit assembly will fit (I think the pedal box is the same, different M/C and booster for discs), subject to doing some modifications to the inner mudguard, actually the flat bit from the pedal box to the mudguard; this has a jog forward on the S3 to accommodate the boosted/dual M/C.
    If planning on fitting the Defender assembly to a S2/2a, I would want to look very carefully at the master cylinder diameter and the size of the vacuum booster - the Defender ones are intended for disc brakes, where the Series 2/3 ones are intended for drum brakes with some self-servo action and different diameter wheel cylinders. Probably OK if you are fitting discs, but otherwise I would be very careful.
