Some OEM info here land rover spring specifications
i have two sets of springs in my garage, want to compare spring rates against the standard one i have fitted, oh by the way what are the standards springs rated at
standard 95 defender spring rate = ???? lbs
unknown set = more info to follow
king spring KLRR-05 = ???? lbs
'95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
'85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
'76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
thanks for the link isuzu110
standard 95 defender spring rate = 270? lbs
king spring KLRR-05 = ???? lbs[/QUOTE]
i just got under the arse end of mine for you mine are KLRRR 320LBS
custom springs //// or so it says .
My fronts are stuffed and rusty as so no use going to look there for part numbers !
Kings quoted me on 400lbs 22 mm wire for the back end of mine with 9.5 turns for $260 a pair .
Having load bearing is fine but i find u lose articulation on overly heavy springs .
Lovells here in WA have given me the biggest run around , i am not impressed with them at all , where as Kings have bent over backwards to help out .
I even went so far as to ring Lovells in NSW and complain to the manager her name is Taneeka , she was not amused either ... yet they stiull stuff me around and everyone else with a Defender
