yellow all,
could someone please tell me how or send me a image file and map file to run on OziCE.
i am trying to convert an image of the wombat state forest map to run on my globusgps.
its a jpeg file and to load it to ozi on my comp i have to load and calibrate map image?????? one i have dont that i use the converter from the ozi web page and get....
wombat state forest OZFX3 file
wombat state forest MAP file.....
so do i just copy them into my ozice in my gps????
any help would be appreciated..
cheers simon
The Meridian Wombat images are available to purchase. I recommend that way as the scan won't be as good quality or as flat as the original unscanned image, and the calibration etc is done for you. Insert the CD into your drive and your web browser will automatically load the instructions to answer that and much more.
But to answer the question, copy the .map and .ozfx3 file to the directory on your OziCE machine where you wish to store your maps (usually a memory card) and then set OziCE to load its Map and also Image files from that directory. Then just open the map and you are away.
Calibration instructions can be found on The Official OziExplorer Web Site - GPS Mapping Software for Magellan, Garmin, Lowrance, Eagle, MLR Receivers.
