20th August 2009, 06:54 AM
Vernier Cam for v8
Hi all ...second try at posting can't seem to find my otherone.
Just got series one discovery and have been told v8 heavy on fuel l haven't yet driven much only to home ,want to do some work on first before go out ,seemed not bad the longer drive i did.Was wondering if anyone has fitted vernier cam gear to set time to optimum and if have did it help much?
thanks for any advice
jbm4u
20th August 2009, 12:15 PM
I think the biggest problem with heavy fuel use is the EFI system, if you want an improvement in fuel consumption I would be looking at a Haltech (type) chip and some dyno tuning, have a chat to Graham Coopers in St. Peters, Sydney, Regards Frank.
20th August 2009, 06:22 PM
You could swap in a Rollmaster timing gears set aligned at the 2 degrees advance keyway, then advance your distributor to around 10 degrees at idle. More torque and slightly better economy.
The 14CUX is quite basic but also can be improved. New generation 4 hole injectors, adjustable fuel pressure regulator and a custom Tornado Systems chip will all help.
A lot of 3.9s are by now suffering from worn camshafts which will adversely affect economy (and performance). But any 2+ ton 4x4 with a V8 will not return brilliant mpg especially in urban driving.
21st August 2009, 03:16 PM
#4
Agree, if you're thinking of new valve train I'd go with a duplex chain with adjustable keyway - not much more cost than standard and at least half the price of a full vernier gear
