Results 1 to 10 of 19
Thread: how to shrink my pics
    Perth W.A.
    hey guys just a quick one for you how do i shrink my images down to the correct size to put on the markets ? thanks
    NSW , Pennant Hills
    Quote Originally Posted by lardy View Post
    Hi lardy
    I generally use Edit Function on the image editing software that's built into the site I upload my piccys to , www.tinypic.com
    it allows to resize your image and save it.
    eg;
    richard4u2 Guest
    i use nero photo snap viewer essentials , came with nero
    St Helena,Melbourne
    4.28 MB
    Irfanview, its free and probably the easiest resizing program available.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Adelaide Hills - SA
    Use Paint. Already comes with every version of Windows.
    Image > Resize/Skew
    (change to, say, 50% or whatever)
    (If you don't like this - CTRL&Z to undo, and try again with a different %)
    File > Save as
    Bracken Ridge, Qld
    Paint is a real PITA if you want to do more than a couple of pics ata time though.
    What's best free one for batch resizing ?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Quote Originally Posted by VladTepes View Post
    Irfanview does batch resizing and batch renaming
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    When I was a kid we used to stick chip packets in the oven and they'd shrink. Maybe you could try the same thing with your photos.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by abaddonxi View Post
    Dont be silly...........................................yo u would only make the memory card smaller .
    1974 VW Kombi bus
    Melbourne, outer South East
    If you use Picassa ( it's good and free from Google.com ) just go to File > Export Picture to Folder.
    A window will come up and you can specify the file size and folder you want.
    If you export to a folder that is synched to your web albums ( if you use Google ) you will bypass the manual uploading step.
